Thanks, Brad and Don 1.
I ordered the Michelin Power Road TS TLR 32mm based on your recommendation and installed it today on my rear. It was a great experience. I installed it without a tire jack and mostly by hand, and only in the last 2 inches, I used a tire lever. I do believe that I could have succeeded without a tire lever. The Power TLR sealed with a regular floor pump and the best part was that the runout was less than a millimeter in both height and width. I don't know how they ride, but the install couldn't have been better and I do believe that I could easily throw a tube in this tire on the road if the hole is bigger than a plug would fix. I have ordered one for the front and I will test them over several hundreds of miles and report back.
Thanks again,
Dan
I just installed my second Power TLR and I got my calipers out to measure the new Michelin Power Road TS TLR 32mm. They average 33.4mm in width with the largest width of 33.65mm and an average height measurement of 29.3mm with the highest point of 29.6mm. I refined my height measurement technique with a level gage on top of the tire to the top surface of the rim with digital calipers. 8 spots were taken for both width and height.
Measured on Mavic UST wheels with 19mm internal widths. The tire pressure was 65 psi and ambient temperature was 82 degrees.
Michelin Power TLR 32mm
Width avg: 33.4mm
Height avg: 29.3mm
Contin GP 5000 TL 32mm
Width avg: 32.5mm
Height avg: 28.6mm
As you can see the Michelin's are about 1 mm in width and a .5mm in height, but the runout is less than 1 mm, so I have more clearance in my frame and brake calipers.
After a 32-mile test ride:
No noticeable ride, grip, or rolling resistance between the two brands in my initial opinion, but the Michelin's seem to lean faster than the GP's. This is likely due to the radius of the tires are slightly different.
Conclusion:
You can run 32mm tubeless tires on a V20, but the clearances are very tight, so you MUST pay close attention to wheel selection, wheel installation, tire seating, tire runout, skewer closure and if running rim brakes, then brake caliper alignment. In my opinion, 32mm TL tire offers a much better ride, traction, and confidence. It was worth it for me to find the right combination of wheels and tires, but my journey is not recommended if you are on a tight budget because I started with 25mm and then ordered 28mm and now I am on my second brand of 32mm tires.
I will report back with an update on the Michelin Power TLR tire's durability and ride comfort.
I can say now that the Power's are much better to install and much less runout than the GP 5000 for the ones that I received.
