v20 freehub size
I use disc brakes. Is one size better than the other for disc brakes?
I have 135mm with disc brakes, fits well. The wheel supposedly requires slightly less dish and therefore has better strength. I have no issues fitting a 180 mm disc rotor.
ccf
I have a wheel with a DT Swiss hub and freehubs for Shimano 11 spd and SRAM XD. I bought an AXS 12spd road upgrade figuring the XD freehub would work, but it turns out I need a XDR freehub. XDR comes in 130mm and 135mm. Which one should I get? I think the two freehubs I have are 130mm, and I have to position my Spyre brake as far outboard as possible. Even then the brake isn't centered on the disc so I have to use the pad adjusters to get the disc centered. So I'm thinking 135mm might be better. Opinions welcome.
This is my latest from Wheelbuilder:
2020 Zipp 303 Firecrest Carbon Clincher 303 Disc Brake…
DT Swiss 240s Straight Pull Rear Centerlock 24H XD135QR
SRAM XG-1295 Eagle 10-52 tooth
SRAM XX1 Eagle AXS
running as a 1x system, shared here
