jcarlo74it
Hi. On a 23mm widht wheel is it possible mounting a 28mm widht tire ....or more wider too ?
P.S. At Paris Roubaix Alexander Kristoff was running Vittoria Corsa Graphene 2.0 25mm tubeless on Campagnolo Bora WTO tubeless-ready wheels that are 19mm wide inside. They worked together fine in previous races. But when he hit the cobbles with them he flatted three times before switching to tubulars. Other competitors were generally using 28c tires. 25c/19c is not recommended in the ISO/ETRTO chart, and is marked by a dot which means it's iffy in the WTB chart.
I never got pinch flats on an upright but found I was getting them often on a bent. Wonder why.
They are quite big, my dad had a pair of 28mm on a 2007 Specialized Tarmac and there was barely any daylight, I replaced them with 28 mm GP5000 and there is excellent clearance.Does anyone run a 28 Conti GP4000S II on the standard Velocity Deep rim and the V20 black frame? I've read that those tires tend to measure much higher than 28 when inflated.
I will say you have two years to get the most out of your V before the PBP and like most you will find it is a long learning curve, so you are starting at the right time. No doubt there are those who hop on a Vendetta and rip away immediately, but that wasn't me and riding on your back is so counter intuitive that your brain will fight you all the way.
However, I've had a number of Vendettas racing at my event the past couple of years to witness they are a thing of beauty when ridden competently and fast, so it's worth persevering with it.
I signed up the the LEL - which starts in two weeks - thinking that I would ride it if I could do it on my V because I knew that riding 840 miles in 100 hours or less on my standard bike was not going to be any fun at all. As it is, as I've said elsewhere on the forum, I'm still riding parking lots. Sufficient to say I will not be flying to London at the end of the month and no doubt will regret I didn't practice enough on the Vendetta to go to Britain to ride the LEL for a very long time.
Maybe we will see each other at the PBP in two years.![]()
While I knew that wider rims make tires wider, I didn't realize that narrower tires made tires taller.I used to have a Maxis Refuse 700c x 32 (tubeless) on the back of my V20. It was on a wide rim (HED Belgium Plus). On a narrower rim that tire was too tall and would contact the brake bridge. Clearance was tight, less than 2mm from the brake bridge. Always made me nervous when riding over leaves and twigs.
When it wore out I replaced it with a 700c x 28 Schwalbe pro One.
