Ahh. Laziness, the mother of invention and sister of efficiency.The turning was just me being cheeky to save walking back up the hill!![]()
The Great Wall (China) fits those criteria perfectly.What some people call limits, others call stepping stones![]()
I agree. Especially going slow... I still occasionally shift left or right if I don't pay attention, after 3 years.When I first took it out on the road, I stayed away from others, because sometimes, it seemed that for no reason at all, I would dart left or right... After a couple weeks, I was finally able to start riding in a more straight line...
Don’t sit up in a fast turn. One time I did that I lost rear-wheel traction and had a low-side crash.If you're riding with others, I would suggest you don't get in a paceline.
Just remember, if you start to feel "wobbly" or unbalanced, sit up... the same is true for tighter turns... Siting up helps keep you balanced...
Blessings,
Rudy
I’m 178cm and got the large. It’s a little too high at the neckline for me. I have longer legs and shorter torso. I trimmed the top of it, and I’m happy with the result.The Thor sport in carbon looks pretty nice!! Seems to have nice lumbar shape. Any tips on sizing.... I am around 174cm, which is around the border from M to L size.... better to go bigger or smaller with that sort of thing? Also, is the neck reset recommended with the seat?
Headrest to get your head more vertical eyes not looking up at the sky let the headrest out. Sounds counter intuitive but it’s correct. On the vendetta mm matter. Doing turns low speed laid back move your head and outside shoulder to the outside of turn. Hope it stops raining. Also recline the seat now.Yeah, the cycle path I use is probably the best cycle path in Australia... definately Sydney. Not the most scenic, but great quality isolated cycle path that you can ride very quickly (I have done it on my DF bike at just under 40kph average). It runs by a motorway and is almost 40km uninterrupted each way. It is so long that it is never that busy except a Saturday morning with good weather. It is fairly hilly, but nothing steeper than 10% and mostly under 5% and all fairly short (up to a couple minutes of climbing, but mostly 30 seconds). Also fairly technical corners (going through tunnels under the motorway exits etc.). It should be perfect to try it out. I'll just pick a time that is not very busy like a week night evening.
And is the best way to get stable at low speed steep hills just to go out and do it? I presume there is no drills you can do on a flat surface to prepare for that.
I think I'll keep the clipless pedals off for a while yet until I can do a few rides without having to catch myself on a tight left corner.
A question about the headrest. My bike came with the performance adjustable headrest but I decided to first try the standard headrest. I find when I adjust this so it supports the crook of my neck, that I am often having to tilt my head forward for visibility and balance. I am not that tall, so I have it in a fair way and that probably results in a more layed back head position. I feel I want my head more upright and not so layed back, but I can't see a way to achieve that adjustment with the standard headrest... Initially I went with the standard headrest to simplify the setting up... but I suspect I need to run the adjustable headrest to get my head more vertical. Anything I am missing on how to adjust the standard headrest?
