The Silvio 1 has NO stalk so not good for height challenged riders, OR using a MTB crankset!I've been wondering about this for my Silvio. Does the 1.0 have the same derailleur stalk as the 1.5?
Rojo, really like your idea here, excellent job!Never liked the OEM headrest rail clamp so I made a better one. Now I can loosen the two bolts and slide the headrest in and out without needing to remove the seat pan and fiddle with the clamp because it's binding.
Larry i think the two al tubes are purely spacers, and the delrin is pulled towards the frame top by two bolts, with the two seat headrest tubes stopping its movement, and hence clamping the headrest tubes in position, and relying on the friction of Al to Al, and Al to delrin to stop any movement.
What a killer light and bracket!This is my older project. 3D printed mount for Phillips front light. It is printed from PET.![]()
I like cutoff of beam but don't like that this light is heavy. I plan to cut it at half, move batteries somewhere else on the frame and switch from Ni-MH to Li-ion batterie.What a killer light and bracket!
Snilard, I see a rear fender in your photos which interests me much. Have you mentioned what brand before? I would love to know what you found to fit. Do you have a front fender? Thanks....I have finally taken photos of some of mine projects on V.
It's Crud Road Racer MK 2. I also use it on front, but on photos I have only rear. It need some fiddling to fit it, but it is possible. On rear I have swapped stays inside out to clear rim. To fit it to front I had to use heairdraier to heat it and modify shape.Snilard, I see a rear fender in your photos which interests me much. Have you mentioned what brand before? I would love to know what you found to fit. Do you have a front fender? Thanks....
Has ratz been coaching you on mallet usage???
EXTREMELY neat cable routing!!
Was the front derailleur cable outer crushed at all going through the clamp ?
Well, I tipped over, for the first time. So I guess that qualifies as doing something with my CB.It's simple, did you do something with or to your CruzBike?
quickbeam said:And as far as I could tell, there were no witnesses
