Tortue
Got annoyed with my T50 front wheel flopping over and occasionally causing the bike to fall over.
Designed a 3d printed part to keep the front wheel in position while parked.
It's tension is adjusted tight enough to hole the wheel, but loose enough to rotate out of the way if/when I forget to disengage it, which I have, several times.
If anyone wants the gcode file FOC, shoot me a DM.
It was printed on a Prusa Mk3 with PETG. The PETG seems soft enough to keep from scratching the paint. Uses a 6mmX30mm hex head bolt and a nyloc nut.
