Is the chainring home-made? I think it is square taper. What is wrong with square taper? My Grasshopper is square taper.
Nothing wrong. The racing industry moved to designs that better secured the crank arms. Most of the remaining square taper cranks are lower priced models.What is wrong with square taper? My Grasshopper is square taper.
Normally they're used for fine-tuning chains on fixed-gear applications. Maybe the builder needed that extra adjustment for reach without swapping cranks. Some people can feel small adjustments.I do not know why the BB is an eccentric, as 6 or 12 mm of movement is not much for seat to BB adjustment!
Good point. Big chain ring, small cogs, short cranks, and possibly unstable ride mean Larry will be going fast enough to warrant body armor.64t is a big chainwheel. Is the cog correspondingly huge? If you give it shorter cranks, you effectively have higher gears
Yes - all CFWhat is the frame material? Carbon?
