WhiteSilvio
Hello there.
I'd just like to point out....
This was an initial setup prior to me starting to ride the Silvio and things got moved a bit once I got going, but generally it is hard to alter the width of the handlebars.
Edit by John R:I was planning on replacing the picture with an edited version but EDIT POST MODE does not seem to allow for attaching picture files, and unfortunately I deleted IMG0445 before i realised that and so now its gone. Apologies for that.
You live and learn.
Arms are almost straight ahead. Hands around the same height as the shoulders. The pictures attempt to demonstrate the difference in frontal area and the funneling effect of the arms with the wider Origin bars.
Spot the difference? Maybe several mph/kph?
"I would suggest taking some head-on shots of Maria in her riding position, because I think there may be more to be picked up efficiency-wise with different handlebars. While the Origin bars are obviously good for everyday use, I have a belief that one's arms are spread out and create an inverted funnel, trapping air."
I notice in Maria's side on shot (from her record run) that her handlebars are quite high, and examination of the picture shows that the spacers on the headset are under the stem clamp device.
I believe if the spacers are on top of the stem clamp that this will help with the aerodynamics by lowering her arms to a more horizontal position, and additionally if road bars were used there would be a further benefit aero-wise.
So while the aerodynamics of the helmet are playing a significant part, there are far bigger gains to be made.
I again point out the front carboyoke. How aerodynamic is that?
All the avenues need to be explored if one is serious about a world record run!
A few thoughts. Regards John R
As I suggested in my previous post:johntolhurst wrote: Tricky stuff, but aero always wins out.
Agreed aerodynamics are important, by "the power of 3!" Double your speed, 8 times the power required to push the same air.johntolhurst wrote: But how many free miles would she get if she had an aero helmet that could be worn that time. Story time. I did a bunch of roll-down tests comparing prototype sigmas to the silvio, swapping rider, andn all that. For some reason I rolled down faster what ever bike I rode. That reason turned out to be the visor on the other guys helmet, (we think) since I was 10% lighter. Tricky stuff, but aero always wins out.
