Carry rack for a CB
Bhride
I'm looking for a rack for my truck to carry two bikes one being a CB. I have searched the forum for any info on this subject but came up empty.
I don't want to buy any ole rack not knowing if it will handle a Cruzbike. So does anyone have suggestions on this subject? Appreciate the help if you do.
Thanks
Cyclechik
I have a Kuat Sherpa 2 and I can carry my S40 and my spouse's DF with no problem. I have to put the S40 on first so I can tilt it away from the hook enough to get the hook between the boom and the tire, but it's no hassle.
Greg S
Thanks
Likewise on the Kuat Sherpa. Two recumbents (1 Cruzbike, 1 high racer) no problem. Also One recumbent, one DF, no problem.
Some opinions:
YOGA_O
I use this Yakima two-bike carrier. I found the QuikrStuff wouldn't work with my son's bike (fenders). I find it better with my S40 in the position farthest away from the car.
I have a Q45 but I'm sure there will not be much difference, what does the vertical clamp grab unto?
The vertical bar that holds the clamp is pivoted at the bottom so it can swing 90 degrees left or right covering 180 degrees. The clamp can move along the entire bar so you can attach the clamp to almost any point on a bike. It's a very flexible arrangement. It only comes for a 2 inch hitch but I used an adapter for my 1 1/4. It's rock solid and I paid less than $400 on Amazon.
LazarGator
A few different ways to load and secure an S40 on a RockyMounts Monorail hitch rack. Using the swing arm on the frame in front of the seat seems most stable and easiest/quickest to secure. Good luck in finding what works for you, lots of options.
orind
I modified my 1-up rack a touch--works well. Just move the spacer down on one side and trim the arms.
