Hope you are okay Mathew
Hope you are OK Matthew - I've had falls like that in the past - always a flat tire in the front - or - slipping on sand or gravel around corners at hight speed.I had a fall today, the front wheel seemed to just slide out. Checking the tire, it was about 1/2 inflated, probably 20 psi. It had been fully inflated before starting about 15 minutes prior, had been holding pressure well since the tube was put in last month. (I usually convert from tubeless in the fall when I transition to more indoor riding.) I checked out the tube and can't find any leak. I'm discarding it anyway, I can't trust it.
Yes, in fact, the build diary is going to explain this in the next few days (I've been on the road traveling that's why there haven't been post for week).For those who run tubeless, has anyone tried the Vittoria Air Liner inserts? From the marketing info, it seems like a possible solution to the dangers of sudden deflation. I know they are expensive, but so is a doctor's visit. If they work as advertised it could be worth it.
I hope you will be able to provide us more on the install process. Perhaps some insights on how to best deal with the 'mess' and tricks to getting it all together. We, your padawan younglings await your instruction, Master.Yes, in fact, the build diary is going to explain this in the next few days (I've been on the road traveling that's why there haven't been post for week).
I got the inserts for only the front to avoid precisely what happened to Matt. All 3 of my major road rashs were caused like that. Once you are an excellent v20 pilot, you depend on the traction of the front wheel for balance. You really have to stop and think about how you ride these bike; traction is everything. So that sudden loss of pressure always causes a fall just like that.
It is not really the loss of steering; it's the sudden loss of traction that makes you simply lose your balance, almost like you got hip-checked by another bike. You go down because you're not expecting it. I've never fallen when I hit something. If I have an impact and get a flat, when the impact gets my attention and makes me go rigid, I say up and ride to a stop. When you are relaxed and fluidly pedal and the air is suddenly gone and the traction with it; ( can be on the straight or carving out a corner), you are on the ground before you know what happened.
Playing with the inserts, they really let the tire hold its SHAPE, and I expect it to let the tire have traction, unlike one slack on air. I tested riding on just the insert and no air; I found it three times more stable than a tire with 20 PSI. It was a pain in the tire wrench and messy also to install, but so far, I'm glad I did.
View attachment 16187View attachment 16188
