By they way, what tires do you expect to install? 28-40mm 26"?
If you intend to install fatter tires (say, 50mm 26") you may want to make negative offset a bit less - say, 4-5cm (remember, suspension sag will add some more trail), or you may run into wheel-calf conflict on very tight turns, or even a bit less if you'd like to install 700c wheels, but with add some angle to the steering - say, 85 or something.
My legs are pretty fat, so it may a complete non-issue to you.
