A video would be great
I'm back it; I'll see about pulling it from the camera.A video would be great
Hey Bob, how do you like the FLEXR setup? Would you recommend I try it on a Silvio 2.0? Would it work with the bottles down on the seat back instead of behind the headrest?Been slowly working on hydration for the Vendetta rides. The showerpass system setup on our Silvio really convinced me that I would prefer to drink out of a hose based system. Since the showerpass unit doesn't fit on the Vendetta I had to keep refining it. I've finally got it dialed. Best part of this setup is I can switch back to traditional bottles if I like.
File inserts not working again; so here's a link to the annotated photo. It looks cluttered from this angle but it's all sitting well behind my head and the storage bags which line up with my shoulders.
Edited: to put the picture inline now that the forum is working again.
Good point that is a long wayHow good a sucker are you???
That is a reasonable way to lift the water by suction!
No option in Florida ! Its gonna be warm water.On the minus side, the hose may be less well insulated than the bottle, so you'll be drinking warm water...
My camelbak insulated tube runs into the (BBB) brain box and you need to empty the tube before you get a cold drink.
So suck up a long drink or blow the line clear and have to pull all the way from the bladder.
The FLEXR system looks designed for bottles to go down below the rider on the frame of a DF, so I didn't think this would be a problem.Good point that is a long way
Thanks for the tips.Jeremy, If you want a low cost way to experiment, Camelbak makes a drink tube that fits on an Eddy bottle. Remember to limit the tubing/mouthpiece from being able to swing free and foul your wheel !!
If you use the stock bite value it slide open and closed to keep the water up in the tube. I forgot about that.The FLEXR system looks designed for bottles to go down below the rider on the frame of a DF, so I didn't think this would be a problem.
Hey I found some with a great discount if you are in Europe they could be a real bargain... 360 euros!!!!!!!!!!Here's the Bontrager Aura 5 TLR at $529.99 from Trek: http://www.trekbicyclesuperstore.com/product/bontrager-aura-5-tlr-front-wheel-clincher-195678-1.htm
Do you have a better source or better price?
Did you try out the new light/camera post when going over a rough bike trail, and have the film star of Mrs. Ratz check out the vibrations of the mount???
