Cruzbike's new post http://cruzbike.com/utility-post works well and looks clean. My previous post was an ugly, but functional, sawed-off handlebar Zipp tied to the cage mount.My other half, who likes to tinker, is making a taillight-mounting post to fit on the headrest bottle-cage bracket.
Excellent, @castlerobber, it's nice to get in the thick of things and rearrange the hardware. I have to roughly handle things before I learn how to use them. Cross-threading is a great way to learn the fine art of screw insertion and removal. Those limit screws have a tight thread and I learned to be sure to have the right size Phillips driver to tweak them. That's why I like Allen and Torx screws over slotted and Phillips because they have a specific size driver that reduces the chances I will mangle the slots. I have one frizzy cable on my bike but I've learned to live with it. Progress not perfection. Good luck with your Q-rings. Even with all the fine descriptions for how to set them I was never completely confident I did it right. On the third try I set it by intuition and it yielded my smoothest cadence.(@hoyden, how's that for wrenching details?)
Yup for sure. Any of several brands.This is the key tool to successfully tensioning the cables: https://www.amazon.com/IceToolz-Fourth-Hand-Cable-Puller/dp/B0028N57KK
Well, I told y'all this was going to be amateur hour...I wasn't kidding.
Nothing I could do would make the chain climb on to the big ring instead of scrabbling helplessly on the side.
Glad you said that!Another pitfall on Silvio's and Vendetta's: if your bottom bracket clamps are not completely symmetrical on your bottom bracket's external bearing cups, it will play havoc with your Front D shifting.
Also one of the cheapest cost tools given the problem it solves....Yup for sure. Any of several brands.
Already had one (Pedro's) from last year, when we were still trying to get the shifting on the S1.5 right, and found it useful. Tried to buy it locally, but the mechanics at the two or three LBS I checked with insisted the fourth-hand tool was a waste of money, and they only used them (if they even had one) to tighten zip-ties.This is the key tool to successfully tensioning the cables: https://www.amazon.com/IceToolz-Fourth-Hand-Cable-Puller/dp/B0028N57KK
Brilliant!!!Modded the back of the sherbet-colored helmet. The red Scotchlite tape is a slight improvement over the Garish Green™ it covers, besides being reflective.View attachment 4360
Now we're getting somewhere.
The handlebars are taped, the bottle-cage mount installed and one cage attached. After having my son take video of me riding, so I could see the crankarm position at full leg extension, I was able to orient the Q-rings better. I ended up with OCP #4 on the bolt below/forward of the crankarm, subject to adjustment.
Does this look like appropriate leg extension? I measured it roughly in the 150-155 degree range.
I rode for an hour after setting up the Q-rings. The adjustable neckrest feels like it's in about the right place, but the top of the headrest tubes kept pushing the back of the helmet up. The tubes are as far in as they'll go without touching the top of the seat back. I'm 5'5". Do I need to cut a section out of the vertical part?
Great BRIGHT clothes to match the helmet!!!Now we're getting somewhere.
That looks about where I ride. My extended leg is not quite fully extended (locked straight), my upper thigh just barely touches the bar on the upstroke, and there's about a right angle at the knee. Your elbows at your side with more than 90 degree bend is similar.Does this look like appropriate leg extension?
I might be able to move it up 1 cm. Much more than that will interfere with the bottom of the helmet, and push my chin down even farther toward my chest. I may temporarily put a wedge behind my upper back and shoulders along with moving the headrest up, before I go cutting anything. From @ratz' picture of the new headrest tubes, it looks like the vertical rise is at least 1" less.Hard to tell from the photo but i wonder if you moved the adjustable headrest up 1-2 cm if that would keep the headrst bar from pushing your helmet?
Hard for me to get over that way on Saturday mornings. I'll for sure be there for some of the Tuesday-night rides, once they start back. So you'll get to see the S30 in person.You need to come ride w Germantown group soon!
So she does. I even found a photo on another thread showing it. I may shorten that distance another 5mm and see how it feels.I think the BB is too far away, with an extended foot, but Maria P also rides the same way!
I was wondering about that. I have thigh clearance on the upstroke, and can sit up when I'm climbing, so I figured it was close to being right.Your elbows at your side with more than 90 degree bend is similar.
I think that this adjustable headrest will solve your problems!!!View attachment 4399 View attachment 4400 View attachment 4401
Some extra padding for your upper back might help. You say there is a new, shorter headrest available soon?
