Good morning all.What is
Good morning all.
What is the bottom bracket thread size and shell width for a Silvio 2?
- Like any road bike, 68mm english thread
What is the chain length needed (number of links) for a 'standard build', or if using the 100mm extension, or the 150mm extension? (so, do I need 2 chains?)
- Like any road bike, one chain, with 100mm extension, 200mm more, 8 inches links.with 150, 300 more, 12 inches
What is the handlebar clamp size (25.4mm? 31.8mm?) if someone wants to fit their own cowhorns or try some other handlebar to a Silvio 2?
- Like any roadbike 31.8 (was 25.4 or 26)
What is the maximum recommended tire size that can be used with Cruzbike 700c rims? What is the inner clearance width of the fork/rear stays?
- Cruzbike rims are like any other 700c wheel rims, 28mm. Inner clearancee is to suit 28mm, standard to road bikes, so I understand.
Silvio Drive Wheel Removal
Wed, 2013-08-14 08:23 (John Tolhurst)
"I meant for the RD hanger on Vendetta 2.0 and Silvio 2.0 to be a snap fit, so once in it would stay there. But it didn't work out that way and there is unfortunately no opportunity for a grub screw fixing as on Silvio 1.5. A drop of supaglue can be used to fix the hanger to the chainstay."
(BTW, this seems like a significant problem - it would make changing a front tire very fiddly to have to hold the bike frame, the wheel, and the derailleur + chain all at the same time to mount the front wheel!)
- This new feature allows the frame to stand evenly when the front wheel is removed.
Just Ordered a Silvio 2.0 Frame
Fri, 2013-08-09 08:55 (John Tolhurst)
"Do you mean the two 'chainstays'? Yes, we have had some vagueness of hole positions on this run. Thanks for confirming."
Tue, 2013-08-27 16:52 (John Tolhurst)
Ring clamp bolts too long - "Ah ha! The bolt exit hole on yours has been welded over, my original prototype sample, no. Thanks for the picture."
Fri, 2013-08-02 08:12 (John Tolhurst)
"We are very low on Silvio 2.0 stock. There will soon be a two month hiatus of supply. I guess I didn't factor in the people who are upgrading."
- Extra time was needed to rework the hydroform moulding. HF mainframes are presently in welding, shipping end November
Silvio 2.0 Build Questions
Sat, 2013-07-06 12:16 (Lavs)
"Also, for IOW "First Snag" Slider Slot - I awoke this morning ready to finish up a few things then do my maiden shake-down voyage,... but had an email from John T. Relating to the Slider not having the necessary slot,... I had wondered about how the Boom clamp would compress the Slider around the boom,..."
(Slider slot missing, also some sliders had a slot without a stress-relief hole - if this has been fixed, you may want to remove the PDF from the downloads, could cause unnecessary angst about the production quality.)
I don't think any of us expect a small manufacturer to be perfect, we just want you to be responsive when issues are found and you seem engaged in the forums. And there is a lot of information in the forums, but it is not easy or quick to read all of the posts to find the little tidbits that are important.
Cruzbike also has multiple channels for updates -- the product pages, the blogs area, and the forums -- it has to be hard to keep all of them up to date. The teething problems above were all discussed in forums, but there was no clear commitment for resolutions that I could find. I think it would be important to potential customers to express fixes clearly so that they know they are buying an improved version.
- With Silvio and Vendetta we are shipping direct to customers from the factory. This tightens the feedback loop down to as little as one or two weeks.
- I've removed the chipslot instruction pdf, thanks for the heads up.
- I havn't announcing fixes where there were two or three instances
