Karl42
Welcome to the neverending quest for low gears and short cranks. Just when you think you have it all figured out, the bicycle industry will have changed all the standards that you've just learned and you have to start over
I started with 165mm cranks on my V20, got knee problems immediately (with 79 cm / 31 inch inseam length). Then I switched to 152mm cranks and my knees are fine. My average cadence is fairly high at 100-110rpm. Maintaining a high cadence on steep hills requires very low gears that are not easily achievable with standard road components. A standard road setup of 50t/34t crank with a 11-32 cassette will give you a lowest gear ratio of 34/32=1.06. For me, this wasn't nearly low enough to spin up steep hills, and you'll find other forum members here that also use much lower gear ratios.
So you either have to make the small front chainring smaller, or the largest cog on the cassette bigger, to get a lowest gear ratio of 0.9 (34/36) or even 0.8 (34/42). Or you can use MTB components, where you can go even lower. It is possible to use road shifters with MTB derailleurs and cassettes with the help of some aftermarket parts from companies such as Ratio Technology, or when using the latest electronic components that let you mix road and MTB parts.
