I have just ordered a T50 frameset. Black frame + black assembly.
Initially I plan to build the bike up with the unmodified frameset parts.
I will use a drop handlebar.
To get the drop handlebars into a suitable position, I'll use a reversed stem. I have plenty of different length options in my cycle spares box.
At a later date, I intend to do an Emeljay mod on the T50's front end and fit a Thor Seats Easy seat to create a poor man's Silvio.
I will use the 31.8mm seat post clamps with rack mount (internal lip filed away) for the Emeljay mod, like rx7mark did. Please see his pictures in
his first post in this thread.
I am thinking of chopping a section of the steerer off with a hacksaw. As far as I can tell, the steerer is 1 ⅛" though I can confirm this as I build up my frameset. Cutting down the steerer should allow the top one of the two modified seat clamps to be fitted the other way around supporting the slider tube closer up towards the handlebars and maybe making the whole assembly a bit stiffer?
I also think that I should be able to remove the Problem Solvers type expanding headset spacer and replace it with a 5mm high, aluminium, 1 ⅛" headset spacer. The stock steering bracket will then sit on top of the spacer. A split sleeve, cut off the bottom of the stock steerer extension tube, will go inside the steering bracket. The height of the split sleeve will be the same as the steering bracket. Another 5mm high, aluminium, 1 ⅛" steerer spacer will go on top of the steering bracket. A star fangled nut will go inside the steerer and a top cap with a bolt, on top of the spacer will then apply the headset tension. The star fangled nut, top cap and allen bolt from the stock steerer extension tube can be reused to do the deed, I think?
Note that the aluminium headset spacers will need to be fat enough to make proper contact with the steering bracket for it all to work.
Thoughts? Clearance to get an allen key into the steerer top cap allen screw/bolt to adjust the headset tension might be a bit tight? A 10mm aluminium headset spacer rather than a 5mm one above the steering bracket might be a better option if it'll fit?
I will post my own pictures when I have completed my own Emeljay mod but that won't be for a while yet.
