Yes, it does work with a 12-speed. I haven’t had any problems at all with it and there doesn’t seem to be any excessive wear on the teeth, but I don’t have any idea how long it should or will last. 10,000 kilometers so far before the change and the 52t teeth were still in good shape. I’ll keep the 52t just in case the 53t turns to be too bigIs the 105 11 speed? So I guess 11 speed chainrings work with 12 speed chain?
Gonna be fun trying it out. If I switch to a SRAM hub and cassette I’ll have access to the 10t that SRAM’s cassettes come with. I’m not sure how much faster the 53/10 will be than the 72kph I got with a tailwind and short descent with the 52/11 at 120rpms. 75kph?I would like to try 53-11 on a segment near me.... I don't need it much, but every now and then!!
I hear ya John. I stay off cross chaining as much as possible on all of my bikes, but especially the V20. I am all for getting as much mileage out of my gear as possible to save money and the hassle of changing them out. I checked the chain stretch with a chain tool and it is only at .5, not .7 yet so while it is time to change it it could be worse. It does show that WD40 for my riding conditions (dry and relatively dust free) works fine, but I am thinking of going with Silca's Synergetic wet lube if I can find it here. It costs only 2 watts more in drivetrain friction than the best waxes on the market, and doesn't wash off as easily with water as WD40 does. I have been relubing every 200-300km with WD40 on all of my bikes for the last 6 years, but I am not ready to jump into the waxing club just yet. I've heard of riders using Synergetic Wet Lube every 1000km with great success, so I figure I can get away with 500km between lubes with my riding conditions. I have already bought a new 138L Shimano 12-speed chain, I just gotta get off my butt to do it.Might be time for a new chain???With that amount of wear, you'll probably need a new cassette also. I replace my chains around 5,000 kilometers so the cassette will last longer. I've used the same cassette for thousands and thousands of miles. I've had the same cassette for two road bikes, and now 9,100 miles on the recumbent. I'd guess at least 45,000 miles.
I'd agree that a bigger chainring would definitely help with spinning out. I don't know that I'd want to be swapping around crank arm length, though. I'd want to stay with the same size arm to keep the pedal motion the same.
Also, you don't generally want to run big-big combinations of gears (or little-little either). That's called cross-chaining. It reduces chain life.
I'd love to stay with my 165mm Shimano R7000 105 cranks because I have my 4iiii power meter on the left arm, but Shimano doesn't offer a 55t for this model. Maybe aftermarket? So, I likely need to get a whole new crankset. Luckily, 165mm cranks are quite common here so I might be able to find a cheapish set.You must be getting strong to need a 55 tooth chainring. Think I would stay with whatever crank length you're using now, and not go shorter. You might miss the torque you get from a longer crank while pushing that 55 tooth chainring.
Yep. My V20 is 118L. This one isn't SilTec, but for about $55 it is pretty good. If I recall correctly CN-M8100 is Ultegra level. With Sil-Tec is about $75 or so in my LBS"Wow, 138L Shimano 12-speed chain"
I heard V20's needed a little more than one 116 link chain for replacement.
138 links should do it with one chain. Right?
Yep, I think you are right on about the V20's chain staying cleaner. Just another "pro" for owning a V20. I am also quite careful about pedaling under load when changing gears. This likely helps in reducing wear on the gears. I wish my large/large wasn't so noisy though. Luckily the max climb I really get is about 10m in about 200m of distance travelled, so I can simply stay on the big ring all day. My mates are planning a trip to Mt. Fuji again so I gotta keep the 2x system for a bit longer. After that, I am going to a single 55t for my river runs. As it is with the 53t, I am always on the small end of the cassette, so this will spread the wear over the bigger gears on it.I use the UFO drip wax. I can't say if it is quicker and I think it does not last as long... but it is very clean to handle the chain, and in the case of the V20 and a front flat... you need to handle the chain a lot... so I prefer a clean chain!
I find cross chaining to not be so baad on the V20.... because the chain length is longer than a road bike, the chain angles are less even in full large/large combo. I regularly go large/large to go over a quick pinch to save dropping to the small ring. My chain wear on the V20 seems lower than my DF road bikes... could be the longer chain, so the wear spreads over more links? I think the chain gets less dirty from dust thrown up by the wheels on less clean roads also.
Regular WD-40, or the bike lube they now make?I hear ya John. I stay off cross chaining as much as possible on all of my bikes, but especially the V20. I am all for getting as much mileage out of my gear as possible to save money and the hassle of changing them out. I checked the chain stretch with a chain tool and it is only at .5, not .7 yet so while it is time to change it it could be worse. It does show that WD40 for my riding conditions (dry and relatively dust free) works fine, but I am thinking of going with Silca's Synergetic wet lube if I can find it here. It costs only 2 watts more in drivetrain friction than the best waxes on the market, and doesn't wash off as easily with water as WD40 does. I have been relubing every 200-300km with WD40 on all of my bikes for the last 6 years, but I am not ready to jump into the waxing club just yet. I've heard of riders using Synergetic Wet Lube every 1000km with great success, so I figure I can get away with 500km between lubes with my riding conditions. I have already bought a new 138L Shimano 12-speed chain, I just gotta get off my butt to do it.
