2 and 3 set hole spacing is 110 mm BCD, evenly spaced holes 130 mm.One has a 2 and 3 set hole spacing pattern and the other is evenly spaced hole all the way around.
Not sure what you are referring to Jason (with the 2 and 3 set hole spacing), but I have seen a couple "different" versions of the Q-rings. I think it is just what is cut out. As long as it is "true" 110BCD, then you are going to be OK. There will still be a lot of "extra" holes for the correct alignment of the rings depending on bike (DF, bent), but for that 24 hr TT, I think you are just going to want to mount the #1 mark in the first hole to the right of the crank. (I'm sure you can find it in the pics on this thread)One has a 2 and 3 set hole spacing pattern and the other is evenly spaced hole all the way around. Do both work for the vendetta or as long as I get a 110bcd 52t ring I'll end up with the correct ring?
You could find out by building a mathematical model. The difficult part would be determining the mechanical advantage of your legs as the angle goes from about 90 degees to almost 180, such as tendon attachments and bone lengths, etc. Then add in the torque as the force on your crank arm changes from 100% at perpendicular to 0% at full stroke (sine wave). Then determine what change in chain ring diameter will cancel out the other effects so that your resulting mechanical advantage is effectively the same throughout your pedal stroke.Looking at rotors website they describe the QXL as a sprinters ring best for fast twitch muscles and high cadences. I'd consider myself the exact opposite of that description while racing a flat 24hr with an average cadence at around 80rpm. I'm wondering if I'd be better off with a standard Q vs the XL. I've used Qrings on the single speed Mtb in the past and they always worked fine for me. I can the difference in pressure if I focus on it but I never really notice the change naturally. I can go back and forth between round and oval and instantly adapt without any effort. I was kind of thinking QXL to feel a greater benefit. You know more is always better right![]()
This is the correct answer.2 and 3 set hole spacing is 110 mm BCD, evenly spaced holes 130 mm.
Looking at rotors website they describe the QXL as a sprinters ring best for fast twitch muscles and high cadences. I'd consider myself the exact opposite of that description while racing a flat 24hr with an average cadence at around 80rpm. I'm wondering if I'd be better off with a standard Q vs the XL. I've used Qrings on the single speed Mtb in the past and they always worked fine for me. I can the difference in pressure if I focus on it but I never really notice the change naturally. I can go back and forth between round and oval and instantly adapt without any effort. I was kind of thinking or QXL to feel a greater benefit. You know more is always better right![]()
The following is all opinion based on the bikes at our house and is recumbent specific where I see the behavior as slightly different than as advertised on DFs. On a recumbent it is more about quad or hamstring dominate than it is about mash or spin.
A 50/36 QXL + 11-30T was plenty good for me on the Oregon terrain the last couple of days and I rode with a pretty severe sprained calf on the century we did (can't walk on it today) that was 5.5k of rollers and I think I would have been good with 8k before looking for more low gears. PluckyBlond was good until about 4.5k then she was looking for about 1-2 more gear inches.
- QXL makes a better little ring than a QRING standard for everyone.
- Big ring it is better learnt on a QRING STD but the QXL is likely better after you are adapted (your MTB experience counts)
- If you are a masher who can spin big watts i.e. OCP 1,
- if you are a steady state rides to a watt plan rider use OCP 4
- If you are a day rider use OCP2
- Always use OCP4 on little ring
- Know the teeth equivalents of the min and max of the QXL And know what you like for gear combos example I like a 53 round a 52Q and a 50QXL
I have a "reg-Q" 52, and an QXL - 53. The way I read the instructions I thought the OCP #1 was for best "flat terrain" riding in steady state. That is what I basically have ridden in both of the large rings. I then mount the "smaller" rings on the OCP #5 for the better climbing aspect.Looking at rotors website they describe the QXL as a sprinters ring best for fast twitch muscles and high cadences. I'd consider myself the exact opposite of that description while racing a flat 24hr with an average cadence at around 80rpm. I'm wondering if I'd be better off with a standard Q vs the XL. I've used Qrings on the single speed Mtb in the past and they always worked fine for me. I can the difference in pressure if I focus on it but I never really notice the change naturally. I can go back and forth between round and oval and instantly adapt without any effort. I was kind of thinking QXL to feel a greater benefit. You know more is always better right
That is why I like them they seem less fatiguing, more smooth, and for me that means better climbing. Power never been proven out for us either too many variables, but efficient equals farther and fasterYeah I'm not looking for a power output advantage. I just figure over 24hrs of smooth effort I could benefit from a biometric adjustment to keep things fluid.
I was just watching the last TT stage of the Tour, and Froome was riding his TT bike on a a KICKR (nice commercial for them) to warm-up and had elliptical rings and they were saying that he got 5% more power from them.
All I can say - is that the jury is out on that for me - It is was "really" true and verifiable - then EVERYBODY on the TOUR would be riding them - and they are not... so what does that tell you?
