Thanks Eric and Peder.
Peder,
Peder, to answer you questions: I am 54! Old man already - playing kids games, like racing! haha. But loving it - keeps you young, plus need to put some pressure on those young guns! You're only as old as you feel, right!
I did race a DF frame bike back 30 years ago for one season. I made it to cat 3. Mostly critieriums, but did dabble in long distance once or twice. Once, on a whim (the same year I was racing) I road 350 miles from Raleigh to Savannah with another racing buddy. We did it in 20 hours total time. I also road in one 600 mile RAMM qualifier up in Wisconson somewhere. I was self-suuported, hadn't riden most of the summer due to work, but tried anyway. I was a DNF. I think I pushed 300 miles can't remember my times.
Anyway, I do love the Crusbike recumbent bike. Due to multiple surgeries on my left knee, I had developed pretty bad varicose veins. I have had them operated on twice in the last 18 months. It helped a little, but I still have pain when my legs hang down. Being able to ride with them up in the air like we do with Cruzbike is a plus for me. Not to mention: no knee pain, no back pain, no wrist pain.
My only complaint is that my rear end is "wet" when I ride for longer than a couple of hours, which makes me raw (if you know what I mean!). I have switched to a Ventist seat cushion and do not ride with a chamois insert, both which have helped a lot. But I still did notice excessive moisture and some rawness after this 12 hour event. Not sure what else to do, except learn to not sweat!
Eric - Are you planning on riding Sebring in 2015? I see it is Feb 14-15. I am tentatively planning on going, but not sure what event.
Peder - Have you done any racing type events, or want to? You live in Norway, right? (My grandfather immigrated from Sweden, hence my last name: Oslund - used to be Aslund; I think, with those 2 little dots over the A)
Ed, The Ventist seat pad is all you need, and do not wear cotton shorts that can trap the moisture. All the moisture just drips through the Ventist pad and offf the edge of the seat. Best thing since slices bread! Good LuckI wonder if you have identified other approaches to sweat management? Any suggestions? I know this is an old thread but I suspect you have it all dialed in now. Thanks for any tips.
Thanks. I do have a Ventist and a foam pad. I swap back and forth. I had mostly used Assos Mille bibs but then switched to a padless recumbent cycling short without a pad and it seemed worse. No tightie whities under there. I'll go to the Ventist exclusively, thanks. I'm not fat but over my normal racing weight, maybe the extra lard is part of it. I appreciate it thank you againEd, The Ventist seat pad is all you need, and do not wear cotton shorts that can trap the moisture. All the moisture just drips through the Ventist pad and offf the edge of the seat. Best thing since slices bread! Good Luck
Ed,Thanks. I do have a Ventist and a foam pad. I swap back and forth. I had mostly used Assos Mille bibs but then switched to a padless recumbent cycling short without a pad and it seemed worse. No tightie whities under there. I'll go to the Ventist exclusively, thanks. I'm not fat but over my normal racing weight, maybe the extra lard is part of it. I appreciate it thank you again
Larry what do you use that has no padding? I have discussed with eleven.cc / breathevelo.cc about special ordering their merino bibs sans chamois but at $200aud the twins say no. Also I am a little concerned the Ventisit pad will rip them to shreds just like they do my chinese nicks.Ed,
I apologize, I did forget to mention that I do not ride with any padding in my shorts. It has been my observation that all it does it soak up and hold moisture.
If you still can't keep moisture from your tush, then I have also found that smearing diaper rash ointment on the "area" will also work. I'm resisting the urge to send how to photos.
I am unsure of the brand. My wife found them for me on a recumbent "site". I think they were about $30 a piece. I have 2 pair and they have lasted 2 years now. I think they are getting a little thin in the back, as the Ventist "is" a little rough.Larry what do you use that has no padding? I have discussed with eleven.cc / breathevelo.cc about special ordering their merino bibs sans chamois but at $200aud the twins say no. Also I am a little concerned the Ventisit pad will rip them to shreds just like they do my chinese nicks.
Not many male sopranos left - you could make some extra cash....Lg is better in the leg but make me sing soprano!
Heavy duty lube seems to be working. I can't get used to the Ventist pad. ThanksEd,
It is basically a woven plastic mesh type of product. It is a little rough on your skin, so if you scoot up and down in your seat a lot you can feel it and it will eventually wear a hole in your shorts.What do you not like about the Ventsit? Considering one
It does not hold me firmly enough and it likes to eat expensive kitWhat do you not like about the Ventsit? Considering one
