When you eventually get a power meter, you'll find that the amount of power needed to go as hard as you can for one minute is nowhere near your peak power. What this means is that the test subject would have to concentrate on limiting his power output when performing a 1 minute test, which could contaminate the results. That would not be the case if he performed max power tests on a trainer setup like trplay built. All he would have to do then is to record his peak power with and without wagging the handlebars and see if there's a significant difference.
Well... yea, you are right I guess. Proving (or disproving) it conclusively is not easy! Of course principle is quite sound and definitely works on upright bikes, but whether it is worth extra frictional losses on Vendetta is yet an open question.
Anyway, I've been analysing my 'bike rocking' patterns once again and again I've noticed something interesting, it goes like this:
At the
top of pedal stroke, you begin by swinging the bars
into the pedal - that extends the distance but it does not matter, because there is no useful lever at the crank anyway.
When your pedal somewhere around 90 deg (maximum lever) you swing the bike to the
opposite side by pulling
hard on the bar end on the same side as pedal. I should note that when done right - this is HARD indeed, and feels like you are pulling up half your own weight... well, that's exactly what you are doing, actually! It should be even harder on Vendetta, hence if you don't have enough upper body strength - you may fail to get any benefit. The harder and faster you swing the bike (or boom in case of Vendetta) - the more upper body contribution you gain, and by starting with bike already 'preleaned' you are getting
double the displacement for a given maximum lean angle exactly when you benefit most - at the point of maximum crank lever!
