No it is not.DavidCH said:Perhaps this is the last message.
yes more medium slow or perhaps karate chop like depending on the speed. If you look close in the Maria climbing video you'll see she is actually almost tracking straight along the fog line not zig zagging. She zig zags when cars are approaching from both ways which is something most of us will do when climbing hard and see danger coming. That is entirely different.
No it is not.
On the other hand, he might simply be not too stable on Vendetta and swinging the boom too hard leads to overcorrections due to flop and steering inertia! I haven't thought about that, and it explains his 'all over the road' comment really well!
Since my boom is much shorter, I have zero flop and much more trail force, I can swing the boom with much greater speed and force and retain enough control over the process.
Much more experienced Vendetta riders can use the dreaded leg steering (that I cannot manage) for those purposes.
All in all, Osiris, I'm sorry, but the problem *so far* indeed seems to be lack of technique on your part, and I've listed exact reasons why. Yea, my bent is better for that indeed, but given enough experience I bet you would manage that as well - you'll have to swing the boom harder and faster to get a 'statistically measurable' effect.
I've described what numbers what you should look for. Since you have a stronger upper body than I do (not hard to, really), once you'll get comfortable with MBB platform enough I bet you'll see some benefit - which is not HUGE, definitely not hundreds, but tens of watts to be sure.
Cycle exercise in the erect position is associated with an increase in exercise capacity compared with supine exercise but with no associated changes in ventilatory response to carbon dioxide production
he dynamics of ventilation (VE), oxygen uptake (VO2), carbon dioxide output (VCO2), and heart rate (fc) were studied in 12 healthy young men during upright and supine exercise. Responses to maximal and to two different types of submaximal exercise tests were contrasted. During incremental exercise to exhaustion, the maximal work rate, VO2max, VEmax, fc,max, and ventilatory threshold were all significantly reduced in supine compared to upright exercise (P less than 0.01-0.001).
https://www.ncbi.nlm.nih.gov/pubmed/10527315
https://www.ncbi.nlm.nih.gov/pubmed/1761025
The following study compared oxygen uptake, HR, and CO2 for upright and supine positions while cycling. Higher VO2 and HR in the upright. The CO2 levels in supine seem to be counter intuitive or paradoxical but the partial pressures are low and might be a factor (perfusion issue).
https://www.jstage.jst.go.jp/article/jjpta/1/1/1_1_13/_pdf
The sympathetic response to CO2 levels is too much detail.
I can't find the study now but younger (under age 44 on average) have less of a CO2 perfusion issue and have much less of a power "loss" in the supine vs. upright position.
I'll read these tonight when I have more time, but from your comments it sounds like the explanation has to do with cardio and oxygen intake efficiency. But if that's the case, why do enormous disparities in power production show up even in 10 second sprints?
the seat angle of the recumbent lowrider (155 degrees, photo 2) are not optimal for maximal power.
According to these measurements the racing upright cyclist can generate considerably more power (mountain upwards or at a sprint), than sitting on the seat.
Note: 155 degrees is not so low.......one can extrapolate the curve to estimate what a 15-20 degree seat would cause.......
http://members.home.nl/vd.kraats/recumbent/pedal.html#Total muscle strength
https://ojs.ub.uni-konstanz.de/cpa/article/viewFile/1788/1661
As an N=1 data point, my peak power (1-5 seconds) on an upright was 1200-1300 watts, my 5 minute power was 340-380 watts, and FTP 265-285 watts depending on fitness and season. HR during time trials 168-171.
When I first got onto a bent 15 months ago, my peak power was in the horribly anemic 500 watt range, 5 minute power around 200-230 watts, and FTP about 150-160 watts. Much much lower. I could not ride with HR over 120-125 without going into oxygen debt and lactate pain. (I got PP into the low 600 watts before undertaking some very specific training to rectify)
In terms of aerobic cycling efforts (say FTP and below), cardiovascular in general and perfusion in particular are to blame for my improvements and I am not done, yet. I also believe older cyclists adapt to the change in position much slower than younger cyclists. I don't think I have read of an upright cyclist jumping onto a recumbent and making the same measured power and few who can demonstrate that they adapted to a recumbent (youngsters Turner and Perez come to mind) to the extent that they make the same power on a bent as on an upright. I plan to peak twice next year and expect my bent power numbers to get close, very close to my upright numbers. This will mean that it took me two full years to adapt and I do believe bent legs is really a bent lung adaptation issue, not leg muscles.
What do you think the effects of age are with respect to anaerobic power? Aside from the few sprints I do on each ride, I've never done any real training. I assumed that being in my late 50's, there wasn't much to hope for, but having seen what even older riders like Kent Polk and John Schlitter can do, I may need to reconsider.
Let me try this one last time. If you want to avoid weaving all over the road, you will have to pull/push the handlebars in such a way that it doesn't result in an imbalance between the steering force generated by pulling the handlebars to one side and the steering force generated by pushing on the pedals. Your advice to just "swing the boom harder" completely ignores this point.
And there you have it. During the time you guys have spent in the last hour playing paper racer you could have shown us those good ol day 1300 watts in the Chop. Great race today. Our group didn't win but were awesome as a team. A good group of women participated today (4-5?). Maybe thats why it went so well. If we keep it up like this a win isn't far away. See you next race. Well probably not but everyone is invited.
Well, I'm 36, was actually 32 when I got into bents. Not a 'strapping young lad', but about close.
Still my experience very closely mimic yours - including estimated FTP and peak/5 minute power (tested on Wattbike/Tacx Neo).
My problem, however, is that BB higher than about 4 inches than the seat gives me foot numbness, and that is actually nerve damage (fortunately, reversible) due to hypoxia. What OTHER systems down below get starved of oxygen and get flooded with CO2? Like, *muscles*?
Ed, what's your knowledge of vascular resistance factors?
I just got back from a 2 hour 45 mile ride.....a real one.
Been doing those since 1960. Really over rated IYAM. Todays race could have used more Cruzbikers in the hunt. Not only is it a hoot, it will give you a little extra pep when going back outdoors. Even more extra pep than the push - pull.
