It was a rush of blood to the head that caused me to buy the bike.ed72 said:the legs are getting less oxygen
Maybe you should test an upright at the 90 degree angle like a comfort bike and compare that to the 90 degree recumbent. I seem to make more power on an upright the lower my torso is while also giving more aero benefit. Maybe that's why the pros don't ride comfort bikes. We know why they don't ride bents.
Funny, your SN suggested liquid rather than gas.It was a rush of blood to the head that caused me to buy the bike.
Read what Balor wrote. Maybe replace the hypothetical lard with a huge inefficient shock absorber that sucks up power from each pedal stroke.
Another difference between an upright and a recumbent is the orientation of the lungs and the initial effect on the V/Q ratio when one takes up the recumbent position. In short, the legs are getting less oxygen, which also explains the often heard.....my HR is lower on a bent.
So, I went back and re-read all of your posts and to be honest, all the talk about FTP and how easy 25 mph is what got me misunderstanding that TT efforts and not sprints were your concern.
On your road bike 4 years ago, your FTP was 210 watts and Peak Power (PP)was 1300 watts....4 years ago. On the V20, your FTP is 280 and Peak Power is around 1100 watts. Has your training plan changed? You do realize PP and FTP are inversely related as pertains to training focus? I suspect if you focused your training on sprints on the road bike, you would get back all the way to where you were 4 years ago unless you are old like me. (and your FTP would also drop)
FWIW.....I did not lose any power lowering my seat to 18 degrees from 20.5 degrees, my cadence is higher by 10-12 on the M5 compared to my uprights, my PP is at least 400 watts lower, FTP is 55-60 watts lower, and 5 minute power is 70-80 watts lower. Cadence is higher by choice to minimize force to knees, it seems obvious peak forces would be higher on a bent at the same power and cadence compared to sitting on a saddle unconstrained on an upright. HR also lower. I am sure my anaerobic outputs would be much higher on the V20. All of those are huge improvements for me over the past year and 9,000 miles of mostly structured training. The performance benefit to a much lower CdA depends upon the course and this will vary from rider to rider and one's understanding of hilly. I recall reading a bent rider claiming the hills at Sebring are "brutal".....
Now I just settle for the occasional KOM and impromptu races against young riders who think they can beat an old man riding some strange contraption.
Fortunately there are no real "hills" in Florida. At least not what we Northerners think of as hills. If there were, I wouldn't even be riding a recumbent. The downhill speeds would be insanely dangerous, assuming I could climb those hills on a bent.
On the subject of effort and HR comparison between DF and Bent to which I see zero difference in my numbers I must also add temperature and time of day have grossly underestimated effects on HR. I've changed up my schedule for work and I'm riding strait out of bed at 5am these last two weeks. It's not cold out here in the morning, in fact it is still like 70-75 degs at 5am but I've been observing some HR value even more odd then normal. My HR actual vs perceived is about 25bmp off so it's like my cardio is still sleeping while I'm riding. A normal threshold effort of 170bpm is only netting me 145bpm then I have to dial it back so much sooner then normal. I'm holding 200 watts at like 120bpm which is pretty damn low for me because it would normally be at least 145. Even weirder is the day before on the weekend I'll start a ride at 7:30am and be holding 170 all day long and maxing out at over 180 so go figure. Just keep in mind how you HR can change day to day.
I find it very strange how you people tell how your quads are limiting factor on a bent, while it was ALWAYS the other way around for me!
My hamstrings hurt from overuse for YEARS on a bent, while quads felt largely underutilized, and I've grown rather large quads from a few years riding DFs - they never felt 'underutilized' there as compared to hamstrings! Glutes - maybe, but not definitely not quads.
Also, it is not the first time I've heard about how maintaining high cadence on a bent is much harder, but there I have not the slightest idea how to explain that...
On a DF riding under 75% of FTP on long events, my cadence is 72 on the flats. This is the most energy efficient cadence for me at around 210-215 watts. Faster speeds would dictate higher cadence for me.
On a bent, 82-85 rpm puts less stress on my knees on similar percent of FTP efforts. It just seems to me that the braced back puts more force into the knees on a bent compared to an unconstrained seating position on an upright. However, at higher power I have found an even higher cadence is better on a bent compared to the upright. So, I TT at closer to 90-93 rpm on the bent vs 82-85 on an upright. I also switched from Rotor QXL rings to regular round Dura Ace rings on the bent, this could be a factor.
I have no idea what my max rpm is on either. Never tried it. Not sure why it even matters.
The more racers and coaches I talk to, the less attention I pay to FTP. One coach told me that it's a "worthless number" for anything other than 40K TT races, where you actually do go flat out for one hour. When it comes to crit races, he tells me that there are many people with very high FTP's, but who have never won a single race.
Training focus on aerobic power or FTP will cost Peak Power and vice versa.
This is a very interesting point. I don't understand why improving your aerobic power will cause a drop in peak power, though. I would have thought the two were unrelated. But if it is true, then I need to stop aerobic training immediately.
