Osiris
Good enough for Larry Oz during the 100 mile record and Aurélien Bonneteau during the hour record, good enough for old me. Who am I to argue to their superior speed. I doubt either gentlemen would put something on the bike willy nilly.
If one of the most successful racers of all time wore purple socks, would you argue with a straight face that wearing purple socks contributed to his impressive performance? Would you argue that he couldn't have done just as well if he'd worn white socks instead? Because that's precisely the thing you would have to demonstrate to conclude that Larry or Bonneteau owe their hour records to Q-rings. You haven't done that. Earlier on you wrote that successful racers like Froome and Wiggins used Q-rings, which demonstrates the same post hoc, ergo propter hoc fallacy. As mentioned in the article I posted a link to, Wiggins has since abandoned Q-rings in favor of ordinary round rings. Has his performance diminished as a consequence? That is the only relevant question here.
Like I said, there have been studies showing slight advantages and I think I was able to measure very small gains. I probably spent a hundred bucks on reagents and 6-10 hours of effort. To bring it to a point, at tempo it was several beats less per minute for the same power and I also measured less lactate at the same power at tempo pace. A mere couple percent but I am a masher. Someone with a different pedal stroke might see nothing but then again some top Pros have used them, probably in violation of their contracts. Thus, I am not so quick to dismiss them.
What you've written here is a textbook example of how not to investigate a claim scientifically. You begin by cherry picking evidence, citing some studies which confirm your belief while ignoring the others. Then you suggest that perhaps different pedaling styles are the reason why, after many years of testing, no firm evidence has emerged confirming any of the claimed benefits of Q-rings. By doing that, you have taken a position that is unfalsifiable; if I and others don't see any advantage when using Q-rings, it's because we're not pedaling properly (I happen to be a masher myself, by the way). Then you move on to the by now familiar claim that "some top pros have used them", from which you leap to the unwarranted conclusion that the only plausible reason they could be using them is because Q-rings actually work. The last sentence, "Thus, I am not so quick to dismiss them", is an attempt to put the burden of proof not on those who claim that Q-rings actually work, but on those who remain unconvinced that they do. You have things precisely reversed. We don't believe claims because they haven't been proved false; we believe them because the evidence suggests that they are true. Ordinarily in cases where there is no firm evidence either way, the proper epistemic position is to merely withhold assent. In this case, however, we can go further than that. Here we have a claim (or set of claims) that can be scientifically tested, and which have been scientifically tested. The results fail to demonstrate that the performance claims about Q-rings are true. But if Q-rings actually provided any real benefit, then surely all this testing should at least show some evidence which cannot be discounted as confirmation bias or methodological error. The fact that we don't see that evidence despite years of looking for it militates against the claim that Q-rings actually work.
