I am pretty happy with my setup. I have most recently been riding these two positions.
This is about 33.4 degrees. The seat stay is about an inch higher with this position than with the one below. The adjustable lower seat mount is about 1/2 inch higher in this position than the one below.
This is about 31.1 degrees. If I keep this one, I will have to modify the handlebars because I have to reach to far.
So, I will probably stay with the 33.4 degree position.
The 2x4 block under the seat looks a little unfinished, but the extra height allows me to see over my handlebars easily even with the <35 degree seat angle. If I go with such a low angle at the lower seat height, I will have to rework the handlebars.
I am still working on the cushions. I cut the stock cushion into several pieces. Tonight I rode with the seat pan part of the stock cushion on the seat pan under the utility Ventisit. I have another piece of the stock cushion under on the Ventisit at shoulder level above the lumbar curve.
This worked quite well but I think it can work better with
@Doug Burton 's suggestion to reduce the lower pad's thickness in the center. The other option is to get a wider Ventisit pad.
Tonight I rode 16 miles at an average of 17 mph which is close to maximum effort for me as my heart rate was averaging 160 with a range of 150 to 170 for the last 10 miles. I didn't have any issues with butt pain or numbness, but did have a little pressure on my right leg because the Ventisit shifted a little to the left. The left leg was very comfortable. This makes me think that a little wider cushion would help a lot with my comfort even at higher seat angles.
I never tried the stock seat at this low of an angle. So, I might have gotten comfortable on it had I kept trying to adjust it. I am on vacation the next couple weeks. I plan to experiment more including the stock seat when I get back.
My next challenge will be storage on the bike. I might go for a Brain Box as a simpler solution than getting a rack mounted with the short and nearly vertical seat stays. I might try to get something to hang behind the seat in the triangle between seat, seat stays and frame.
For the moment, I am hanging a small handlebar bag off the back of the seat.
In any case, I can ride more than an hour at a time in comfort. My speed is faster than any other bike I have owned. I recently changed my 36 tooth chainring for a 40 tooth oval ring and I am in top gear a lot (even on nearly level ground). I might have to get a bigger one or give up on the 1x11.
I am enjoying the ride immensely. Thanks for asking.
