The ventiseat pad is offered from Thor once you pick the style and size seat you want during the checkout process. You also get to choose the thickness of the pad as well. My Thor was delivered with seat, ventiseat pad, and mounting hardware. The stock Q45 seat pad, given that it is designed to fit that particular seat and size, would not work on a Thor. Too many styles, contours, size differences, etc.Will the ventiseat pad from the Q45 stock seat work on the Thor seat ?Or do you have to buy a new Thor ventiseat pad . I did not see any ventiseat pads on the Thor website
You are correct, placement of the seat tube does allow you to change the angle to your liking.Looks like there are angle degrees for proper fit by placement of the seat tube
Kit? Not that I’m aware of. Like you, I scoped out a few posts on the forum, zoomed in on some pics and rigged up a set up for myself. I’m a noob when it comes to that stuff and it wasn’t too difficult, drilled a couple of holes (which needs to be done with a Thor regardless, nothing is pre drilled), made a trip to local hardware store to grab a couple of things and that was a wrap. For me, and everyone is different, totally changed the riding experience on the Q45 over the stock seat.
Here is what I did.Hello. It seems like the Thor seat is a popular alternative for Cruzbikes. I'd like to give it a try this upcoming season. I've seen the various posts where people have jury rigged their own solutions for mounting the seat, but has anyone selling a mounting kit to do the same?
My bad. I meant that your pictures were perfect, @cpml123Here is what I did.
Introduce Q40-45ish
I spent past several months to upgrade my 2021 Q45. The weather finally got decent, so I took it for a quick ride. everything seems to work, at least around the neighborhood. We will see if everything stays together when I ride to and from work later this week. Major updates... Thor GS large...forum.cruzbike.com
I pulled my set up idea directly from @cmpl123 so it’s exactly the same.
Not to complicate the seat discussion even more but some (myself included) have also tried a mesh seat. I had one from a long when base recumbent and thought I’d try it out. I was able to use the Q45 brackets to install. I put over 5k miles on this seat with my other recumbent so it was broken it very well. This also offers a very comfy ride on the Q. Depending on which mesh seat, they can be a little more expensive than a Thor. Not sure I would have purchased one (maybe used) to try but since I had one I figured why not.
Thanks, @vmi1056 . It's good to know that the same setup is working for both you and @cpml123 . What is the white material that you used to apparently bond or pad the seat post against the seat back?
Also, I had another recumbent before my Cruzbike, and it had a mesh seat. I did like it, but I don't have it any longer and I'm going to give the Thor seat a go. Now that you've tried both, which do you like better on your Cruzbike? The Thor seat or your mesh seat?
It's thermo plastic. I use it between the seat back and the u connector so that it has bigger contact surface area and won't rattle. It is not a bonding glue.What is the white material that you used to apparently bond or pad the seat post against the seat back?
That is exactly the set up I have been trying to get, I was thinking I would have to see if I could order the hard shell seat from hp velo which is a seat I really really like a lot but, of course, I am a million miles away from a dealer and they make it clear on the site that's their business model. I didn't know about the god Thor making seats along with lightening, thunder, etc. Thanks for the pics and thanks everyone for the info, off to find Thor...Same experience for me as @vmi1056 said. Don’t know of any kit, but not too hard to do. Mine is more reclined & very comfortable.
What Thor model did you order? Trike? Sport G? Easy GS?Same experience for me as @vmi1056 said. Don’t know of any kit, but not too hard to do. Mine is more reclined & very comfortable.
What Thor model did you order? Trike? Sport G? Easy GS?Kit? Not that I’m aware of. Like you, I scoped out a few posts on the forum, zoomed in on some pics and rigged up a set up for myself. I’m a noob when it comes to that stuff and it wasn’t too difficult, drilled a couple of holes (which needs to be done with a Thor regardless, nothing is pre drilled), made a trip to local hardware store to grab a couple of things and that was a wrap. For me, and everyone is different, totally changed the riding experience on the Q45 over the stock seat.
I got the carbon Easy GS, Size Large, reinforced, with Ventisit & neck rest.What Thor model did you order? Trike? Sport G? Easy GS?
