I've run tubeless on HED Belgium plus, A23, FLO30, and FlO60 rims. I have used Specialized S-Works, Schwalbe Pro-one, Vittoria Corsa TLR Speed, and Compass tires tubeless. On some rims Stans tubeless valves stems have a bulbous end that pressed against the inner wall of the rim making it impossible to seat the bead. I spent months trying all manner of tape trying to seal the HED rims and even had contact with HED support personnel. My suspicion is they used some sort of mold release type agent (silicone) that permanently contaminated the surface. Some tire/rims are easier to seat than others. None were fun. I had unsealable flats using Schwalbes on every Brevet and tossed them all into the garbage but I hear they fixed the early casing problems. I ran tubeless during the TRANSAM bike race. It was 110-120F for the first week. One of the racers from Finland had the same Schwalbe casing problem at 1 am the first day, he was screwed and had to walk all night back to a bike shop where he downgraded to normal tires/tubes. During the race, I kept losing air and had to refill 2-3 times per day, I guessed it was hitting huge potholes all day and a slight burping of air out of the rim/tire interface. After a week, I decided to retrofit back to tubes. Surprisingly all of the 80-90 ml of sealant was one hard booger. Anybody ever try to remove the tubeless valve stem and convert back to tubes in the middle of the night? In the rain?
After a couple years, I have decided tubeless has zero value for me and now run latex tubes with sealant inside them. Tubeless is not faster, lighter, cheaper, longer wearing but they are a major PITA. YMMV
