Hey All,
I swapped the crankset on my V20 on the weekend. While I was at it, I noticed the drive side bearing is pretty crunchy and seems to be on the way out so I want to replace it. Has anyone got the full spec for the V20 Bottom bracket? I believe it is a SRAM GXP, but not sure what thread etc. This was on a 2020 V20 builtup bike from Cruzbike... so whatever CB supplies as standard would be fine.
Incidently, I installed a BBK 155mm crankset (GXP) with 52/36 rings. So shorter crank arms and longer gearing. I have not ridden it yet, but hoping the shorter crank allows for more consistent power and perhaps a small amount of aero benefit while also allowing to spin quicker.... and combined with a couple more teeth on the big ring, should allow me to pedal out to 60kph or so. Not useful for flat roads (where I was fine pedalling to about 50kph with the old setup).... but I do run out of cadence sometimes pedalling down some long 2-3% declines near me.
Cheers!
Cheers!
