Oh ok, that makes more sense. Weird that they're using circumference in the first place. A 2170-millimeter circumference equals a 691-millimeter diameter, and a 2175-millimeter circumference equals a 692-millimeter diameter. And the difference is halved when comparing vertical tire clearance since that's only the radius.Well, that's circumference. More than three times the diameter.
That at least partially explains why your tire is shorter since wider rims make tires shorter.26mm internally, 31mm externally (on the outside edge. Does bulge out a bit over the rest of the shape. They are rated for tyres 31mm to 60mm. (I have a table that says this rim width should allow more, but they will have their reasons.)
I got these:
I was ordering there anyway and most other trispokes and such were not designed for anything more then 28mm.
