Misc build photos
Front triangle with slider and handlebars separated:
Steerer tube spacers and top cap. Changing the order of assembly lets you fine tune the height of the Vendetta's attack angle so to speak. I started with the pivot clamp at the bottom with the three spacers on top but kept raising the pivot clamp to give me clearance around the water bottle and cage until I got it on top with the three spacers below:
Note you rotate the pivot clamp pin forward to use the most forward pivot cage hole or rotate the pin aft to use the most aft pivot cage hole. Pretty clever way to adjust handlebar reach separate from pedal reach, eh?
Intermediate height, one spacer below pivot clamp, two above.
Two spacers + picot clamp + last spacer:
Pivot clamp all the way on top with three spacers below:
On the Wahoo KICKR:
SRAM Rival 53x39 crankset. 170mm cranks.
SRAM XG-180 11x36 cassette.
Shimano PD-A530 dual platform pedals - I was tempted to get the ones with black platforms but read about of lot of paint chipping off from cleats etc so I just went with the plain ones. Also Wahoo Blue SC (Speed and Cadence sensor), SRAM Rival rim brake, and Zefal water bottle cage -
NOTE: I had to elongate the mount holes in the water bottle cage slightly to be able to adjust the position back slightly in order for the H20 cage base to clear the pivot cage weld bead..
Front brake tolerances with the fork are extremely tight.
SRAM Rival brifters with the rubber hood pulled back to run the shift cables, brake cables, and to tighten the handlebar clamp.
NOTE: SRAM Rival brifters come with the shift cable already installed on the brifter but you do need to feed and seat the brake cables.
SRAM gives you the option of routing the shift cable in one of two different ways. You can run it to the outside of the bar or to the inside. The brake cable follows the inside path so you can run the shift cable alongside the brake cable or brake on inside and shifter on the outside.
SRAM MTB X9 TYPE 2 roller clutch rear derailleur mounted to the RD hanger.
Nifty Cage Lock feature - makes drive wheel removal easier for fixing flats and mounting the bike on the KICKR. Do you see the little button with the lock emblem on it? You manually extend the RD cage until you can press this button which drives a pin to catch and hold the cage in the extended position.
Rear view shows the RD hanger better
Starting to setup the FD on John's custom FD stalk design. Works really, really well but with the curved piece of housing looped under the bottom bracket and the spring on the FD, setting the initial tension by yourself with no cable puller is a royal pain in the bum.
Cable runs are very, very neat on the Vendetta. Cable housing goes from brifters along handlebars where they will eventually be covered in bar tape, then internally to the slider and out the pivot cage via this oval hole on the bottom of the slider up near where the handlebars mount.
My new Topeak D-Tork DX torque wrench. Pricey little bastard but exceptionally nice piece of kit. 4-80 N-m range, with the ability to toggle between N-m, in-lb, ft-lb, or kg-cm.
Checking the rear brake cable run before cutting some housing to fit. The rear brake cable uses internal frame routing.
Here is the aft end' left side as seen from insode the frame tube. I was able to stick the corner of my iPhone containing the camera lens inside the bottom lightening hole to take this photo.
NOTE: It is very, very easy to run this cable. Stick it in the top and push through to your fingers inside the bottom lightening hole on the HF tube and guide it out the rear fitting with your fingers. You can even watch/see this as you are doing it.
You do file and clean up the ends of your cable housing cuts, right? It is hard to get the iPhone camera to focus on the end of the cable housing..
Rear brake cable housing. I ended up trimming this about a 1/4 inch shorter than shown here.
Rear brake assembly.
NOTE: I had just installed it but had not adjusted it yet so no lip from the peanut gallery about the brake pad orientation, etc. Those Gator HardShell tires look pretty cool.
NOTE: Do you remember where I said earlier the leading edge of the seat would rub the paint on the frame? This little pad is covering an abrasion made by me just carefully sitting in the seat checking the fit of things - well before riding was possible. This pad came with an iPhone case I had bought. It is similar to the pad on the end of a pool cue but softer. Works perfectly!
Wahoo RFLKT mounted and the cable runs for the SRAM brifters.
NOTE: The standard brake cable housing provided in the SRAM Rival DoubleTaps is NOT long enough to do all of the brake cable runs. I had to buy about 3 more feet - so I bought 4 more feet for about $8 USD just to make sure. That left bare cable is for the rear brake.
Left brake lever = rear brake and right brake lever = front brake on my Vendetta! And yes, I did ride motorcycles for many years for those who are wondering.
Wahoo RFLKT loading pages. It only does this when you first turn it on. You can customize the number of pages and what each page displays within the limits of the RFLKT's memory capacity. Very, very cool and handy device.
This is just the test utility result. You also use your iPhone to deliver firmware updates to the RFLKT as new features or bug fixes come out. For example, if the Shimano DI2 electronic shifters transmit status via Bluetooth Smart or ANT+, the REFLKT could be customized to display what gear you were in and whatever else the DI2 might be capable of transmitting.
This is my default page:
- Top left GPS indicator
- Top right Unit indicator for the first cell which is configured to display total ride miles
- Next cell is total moving time
- Left cell with speedometer icon is current speed in miles per hour
- Right cell with Cad label is current cadence
- Bottom cell displays my iPhone's battery status, numerically and with a staus icon and text label
All of the above and more are all customizable to whatever you want to display. Typically you can load about 4 pages in memory. There are also 4 buttons. They don't show well in these pictures but they are two on each side. The top two (left and right) are roughly in line with the 5.95 miles being displayed. The bottom two (left and right) are roughly in line with the speed and cadence display cells. All four buttons are programmable to do all kinds of things and within limits can be different on each page.
Button combinations can also be programmed - for example pressing and holding the top 2 buttons for 5 seconds at the same time resets the RFLKT and causes it to reload the pages from whatever app is currently connecting to it. Pressing and releasing the bottom two buttons toggles the backlight on. The backlight is currently set to stay on for 30 seconds and then automatically go back off but this can be changed to longer or to require another two bottom button press to turn back off.
The RFLKT uses a CR2450 coin size battery which is projected to last about a year as long as you don't make prolonged use of the backlighting.
Front SRAM Rival rim brake about to get its cable housing - NOTE the filed cable end!
NOTE: I ran a cable donut about midway along the internal frame routingto try and minimize the risk of the cable rubbing the frame. As you can see in this photo I am using a piece of cable housing to shove the donut to the position on the cable where I want it to be.
In this shot you can see more of the lightening holes in the HF tube as well as a little bit of the sissor-jack headrest clamp John invented.
Sizing my chain. NOTE: I used two methods to cross check I was getting the size correct:
- Sheldon Brown guide showing chain overlap with new chain set on big-big but NOT threaded through the rear derailleur
- Park Tool formula to calculate chain length: L = 2(C) + (F/4 + R/4 +1) where L = Length, C = Chainstay length, F = Number of teeth on largest front chainring, and R = Number of teeth on largest rear cog
- For my gearing and chainstays this worked out to be: L = 2(19.5) + (53/4 + 36/4 + 1)
- L = 2(19.5) + (13.25 + 9 +1)
- L = 39 + 23.5
- L = 62.5 Normally you would round up to 63 inches but comparing the formula result to the overlap method indicated it best to break the chain right at the 62.5 inch mark so the power links would line up.
SRAM PC-1071 chain installed.
NOTE: This most commonly comes packaged with 114 links which is not long enough but Cruzebike sends along an extra small length of chain with anothe power link so my chain has two power links to end up with one chain long enough to fit my setup. It still beats a freaking 10+ long chain, no? Koda is supervising to make sure I do it right.
Measuring my wheel rollout length to get the actual circumference of my wheels and tires to plug into my Cyclemeter App.
Koda hair included at no additional cost... Sigh, this is the time of year she sheds her winter undercoat.
Except for bar tape and final tweaks to get the shifting cleaned up she is ready to ride include lighting and my Bachetta Brain Box.
And no, I did not keep the boxes.
Any other questions about how something goes together? Any other photo requests? Let me know and I'll try my best to accommodate.
PS - I am a bit over 5 feet 6 inches. I have a 28 or 29 inch inseam, a 38 or 39 inch xseam and fully reclined and stopped I can fit both feet flat on the ground. Very, very comfy position. Looks extreme but feels way less when actually in the seat.
For a different look, here is my youngest son who is about my height but is skinny and not built like USMC Lt Gen Chesty Puller like I am.
