Questions Answered and a new one
Ratz,
Thanks for the reply, I am surely glad to have put DI2 on this machine as it's quite a handful for the first few miles and the DI2 makes changing gear one less thing to think about, and of course once experienced there is no going back.
The battery is mounted in the lower boom at the top end, I had to trim the boom or is it the slider, the lower of the two, for leg reach, this bike as you probably all know needs building in the reverse of a conventional bike especially with DI2 all tucked away in the boom/slider, the leg length pretty much needs sorting from the off unlike the last thing to do on a conventional.
It is a bit of a fiddle putting the boom & slider together and pulling the cables gently through the bottom hole with the battery in there, but working on the assumption I haven't got to get in there again for a while. Fitted shimano grommets to the top cables used shimano internal cable binders and a length of Shimano external covering to run the RD cable down the inside of the front 'fork' if that is its name (piece that runs from crank to wheel hub). With the 5 port in this position had to add dowels to the water battle carrier, but the junction is well protected here.
Cables, with the 5 port junction just under and not far from the bars I used 2 x 400 1 x 650 1 x 1200 1 x 1400 if I did it again I would go to next length up for the 1400 as it was only just long enough allowing for the movement on the RD and then leave the excess up the boom.
Found the seat pre drilled holes for extra water bottles useless as they need seriously long packers or dowels to make them work and then could wobble around so mounted them further back.
Alan,
Good to know another V is so close we ought to get together for a NewForest ride, we are off to Lanzarotte in Mid Jan and taking the V with me where I hope to become real confident with the thing, I am looking to do LeJog In May or the London/Nice ride June both organised with Discovery Adventure, and on previous LeJogs taking as many as three saddles with me for the event hoping the V is the cure, just hoping it's as fast.
Question,
Maria described the photo of the below component as the backrest scissors, I am none the wiser anyone give me a clue on where it goes on the new V20
many thanks
phillip
