So today was my last day to make a strategic change. I want to make a watts plan for the 12 hour ride. But there is always a discrepancy between Power Meter Power and Kickr Power. Typically Kickr Power reads about 10 watts higher than Power Meter Power but unfortunately it not linear so you can't just subtract 10; instead it varys over the curve as power increases.
The TrainerRoad software has a really nice feature that lets you train using the Power Meter reading and it adjusts the ERG trainer to make your power meter effort hit the target. This is different than just telling the ERG trainer to do it's things and maintain a fixed power. Until 3 or 4 weeks ago that feature worked really poorly in iOS for some meters. PC /Mac version worked fine. This last version nailed it finally. But unfortunately switching modes means taking a new FTP test to calibrate to the new meter.
So I gave in and did an FTP test on no rest. Decided to do it Keto and Fasted, after the test I took on calories while riding. Since this was a no rest test I modified the test to be one quality 8 minute block and not two of them. Two is gives you more consistency but I've gotten pretty good and nailing them now; and if I did two I would not have been able to finish the rest of the riding schedule for today. So today was a 45 minute FTP test; and then the ride Mount Drum minus the last 45 minutes.
Pretty happy with the results. FTP on the P1 pedals was up 4 watts from the current level have been training at; that pretty much is an effective gain of 14 watts because I know the pedals read 9-15 watts lower than the kickr; and right about 10 low at 260 watts. So for the 6 weeks of training completed on the Sebring plan so far the "pedal adjusted" FTP gain is around 25 watts. which is about 5 watts ahead of where I was on Turkey day when I had to take the unexpected 2 weeks off. Structure works; it can be boring, but it works. And it is not like we can ride out side when the weather is -6F.
Rides in power match lacks the smooth power line on the graphs because they show real instantaneous power. (Larry also trains in this mode) versus ERG power which is smoothed heavily by the trainer to give you a silking smooth ride.
Then I moved on to the over-cooker test that is Mount Drum.
This ride are used in this plan at this point in time is contrived to set expectations and remind you that going too hard for 3.75 hours or outdoors for 6 hours will make you go Boom. This is important. It is easy to get over confident riding in ERG mode for weeks and weeks on end. I just barely finished the 3.75 hours total work.
Tomorrow is a rest day yeah.....
So evaluating the ride; my back was fine, my arms were fine; but my feet cramped and I got hot foot around the 3.25 hours mark. Those are bad indicators for the 12 hour. We have been using a time compressed training schedule so that Monday - Friday is almost always 60-90 minutes of high intensity sweet spot work; with the mega endurance hours on the weekend.
The plan contains "drop" rides that are optional if over tired; they are also substitutable for equal TSS rides with different objectives. Since my body was not ready for that many hours, next week I will drop the shorter length rides and replace them with longer but easier rides that will net the same TSS but force me to sit on the bike for longer hours and build up just a bit more tolerance for the extend hours. Time invested now should be paid back on event day.
The Planned Swap outs will be
Wednesday -- Spruce knob 90 minutes 95 TSS ---->> Warren+1 135minutes, 97 TSS
Friday --- Whorl 75 minutes 50 TSS --->> Conness 165 minutes, 111 TSS
If burned by Saturday then Saturday's high intensity workout can be swapped
Leconte 90 minutes, TSS 124 IF .91 ----> Big Squaw 150 minutes, TSS 121, IF .69
Then Mount Blackburn is the 2nd of the Dreaded test rides. You know it's coming this time. It is again and over reach.
Next effect 3.25 hours more saddle time but less intensity. The Tues, Thursday Sunday rides remain core to the plan and do not get swapped.
After Blackburn it is time to access how it went to decide if week 8 stands, gets modified, or needs a taper.....
