Some are - like DT Swiss.
the numerous replies, tricks people have listed and mishaps described all make my point. And yes I have been riding for fifty years and built bikes so quit shooting the messenger. I have the new T50, there are no instructional videos on changing the front tire or even a warning that it is as tricky as everyone is saying. To get out on the road not knowing that is disastrous.
Robert, another excellent video!!!Here is a link.
I just found that out too. Gone now.Throw the QR springs away. How many people knew that? Everybody except me?
post: 154955 said:...The idiot who built these bikes with that system is *%$#@^&*%$.
Robert, Thanks for the boom misalignment suggestion, I will recheck!!!OK all - here is another pro tip that I imagine I should re-edit into the video. Or maybe a new one. Bear with me:
Your front end - if it is popping out all over the place all the time, must have some kind of static tension on it because something is misaligned. The fork - when aimed straight - and the chainstay/boom/slider assembly - when pivoted down to meet the fork, should go on totally 100% aligned so the skewer goes straight through one side, the hub, and the other without forcing or needing to "tweak" one side.
If the front end has been adjusted - and all the parts aren't aligned correctly - the tendency of the stay is to need a "twist" to align correctly with the fork. I believe I cover this at least in the build videos. I used to see this on the older Suspended Silvios when someone would make a boom adjustment and not release the tension at the BB clamp bolts or skewer, causing the front stay to be under a serious amount of tension sometimes bent the wrong direction.
But even under some tension this change is not particularly difficult. Some RWD recumbents (depending on the derraileur/hub/brakes) are a more serious headache than any model Cruzbike IMHO and I spend every day swapping wheels and changing tires on all kinds of bikes. I do not rank the Cruzbikes as any more or less difficult than any other bikes. Just different.
