Osiris
I did some field testing of my own this morning, comparing the results of three of my helmets: the Specialized Evade, LG Vortice, and SH+ Eolus.
Aerodynamic efficiency was the only thing I wanted to know, so I drove out to the backside of Sugarloaf hill. The front side is steeper and longer, but I'm not interested in knowing how helmets perform at speeds exceeding 40 mph, nor was I prepared to repeat the climb to the top of Sugarloaf 15 times on a broiling hot day in July. The backside is ideal because it's sloped just enough to achieve speeds of 35+ mph when coasting down on my Specialized Venge, and the climb back to the top isn't nearly as demanding.
I had planned to do the tests in groups of five for each helmet, but I seem to have miscounted and did six runs with the Specialized Evade. No matter; more data can't be a bad thing. Each test was performed with my hands in the drops, starting at the very top with a rolling speed of ~5 mph, and then just coasting all the way down.
Below are the top speeds achieved with each helmet:
Specialized Evade
34.0 mph, 35.6 mph, 35.1 mph, 35.3 mph, 34.2 mph, 36.9 mph. Average: 35.18 mph
SH+ Eolus
37.1 mph, 36.7 mph, 37.4 mph, 36.5 mph, 36.9 mph. Average: 36.92 mph
LG Vortice
36.9 mph, 36.9 mph, 37.4 mph, 36.7 mph, 37.4 mph. Average: 37.06 mph
As I suspected, a road helmet just doesn't belong in this sort of company. Even at 27 mph, I already experienced a lot of wind resistance and noise, and by the time I hit the top speed of 35 mph, it felt as if it had a parachute attached to it. It's only saving grace is the amount of cooling afforded by all those openings in the top and sides, but you pay for that with the enormous turbulence they create.
The surprise was the SH+ Eolus. It's better ventilated than the LG Vortice and leaves the rider's ears uncovered, but it doesn't give up much to the Vortice in aerodynamic efficiency. At the slower speeds I normally travel on my bents (~24-26 mph), the difference in efficiency between the Eolus and Vortice might not even be noticeable. However, on long rides you'd want better ventilation, and the Vortice would be a very poor choice except in colder weather. On a typical Florida Summer day, wearing the Vortice for long periods might prove fatal.
I should mention that the Vortice might not even be usable on a bent due to clearance issues with the rear tire (in the case of my M1) and getting it to fit whatever headrest you're using. It might be possible to modify the helmet for use on a bent though, and this is something I'm going to investigate.
Specialized Evade
SH+ Eolus
LG Vortice
