My SH+ Eolus helmet just arrived!
My initial impressions:
1. The first thing I noticed when taking it out of the box was how light it felt; it seems no heavier than a conventional Styrofoam road helmet. Whereas the old model has a thick outer shell and relatively little padding inside, this one has much thicker padding and the outer shell is just a thin layer of plastic. Weight savings are evident even in the visor, which is made of much thinner material than before.
2. It comes with two visors; one in clear plastic, the other featuring a dark reflective tint. The shape of the visor is much improved as well. It covers more of the rider's face, shielding everything above the tip of the rider's nose, and the downward curvature of the lens is greater, making for a better air seal at the edges. The greater outward "buldge" of the visor should allow ample room for a pair of glasses to be worn underneath, which was not the case before. The visor is held in place by tabs that fit into slots in the outer shell, and can be easily detached, unlike the old one.
3. The shape of the helmet is different in more ways than I expected. The rider's ears are now fully enclosed for improved aerodynamics, and the overall shape of the helmet isn't round any longer, but more of an egg shape. Gone are the top and side vents. The only openings in the shell are two slots in back and four small cutouts in the top of the visor. No doubt this makes it more aero, but the lack of adequate ventilation could be a problem in hot weather. While the old model had lots of air space at the base, the new design comes with an inner "fairing" that seals up the gap between the rider's neck and the edge of the helmet.
It's really too hot and humid to ride the M1 low racer, which sits mere inches above the searing pavement, but I'll at least have the opportunity to test the helmet for fit once the M1 is back on the trainer, and I'll probably do some test rides with it on the M5 high racer and Cruzbike V20.
