Correct. I only used rubber cement because it was used in the video. The super glue trick worked. I did an 80 mile out and return yesterday. The covers stayed tight. The only problem was that a rock went through one side of the cover and got stuck in between the covers. Fortunately, holes in Monokote are easily repaired. Covered one of the front wheels yesterday. I could not find the brand of window film you mentioned, got Frost King locally, because it was the thickest, at 1.25 mils. Held up no problem overnight. I used Monokote on the outside, and window film on the inside. The window film cover looks seriously ugly, but is a lot less expensive. Thought that would make a good test between the two cover materials. The double stick tape is clearly better than the rubber cement, but more difficult to work with.
So, my impressions:
If you absolutely positively have to have wheel covers and:
1) you have more time than money
2) are a total weight weenie
3) have metal rims (I am sure one could do this with carbon rims, but if you can afford carbon rims, you can afford "real" wheel covers, right? Besides, solvents to remove the glue could damage carbon rims.)
4) have drum or disc brakes
Then, this is a viable system.
I will be doing a century in less than two weeks from now, so will keep y'all posted.
