I have to admit - the
I have to admit - the QRings were scary magic to me.
I didn't understand them so I didn't touch them (I left them how I got them on the bike).
But...I finally sat down and read and re-read JT's instructions, Ratz' description, the pictures you guys put in here (which helped a lot for me) and took the plunge.
I took a picture of my original setup (as it came) which turns out it was in OCP #2.
I did my dead-bottom measurement.
Fiddled around a bunch, got it all set up and 90min later it came back to OCP #2.
SO...I read about what happens in what direction (Going #1 or Going #3) and figured if anything my boom is a bit shorter than it ought to be - so I went with OCP#3.
I *think* it's better.
It feels smooth. OCP#2 was okay too - maybe a bit lumpier? hard to say.
The bottom point of my right patella is healing faster tho than ever.
I still get some pain when I hit the higher wattages - but if I just keep the max under ~600W I don't really feel it.
I think that's better - and it still feels fast.
One other question for you experienced mechanics tho...how in the HAYLL do you get to the chainring bolt underneath the crank arm? SRAM Force Crank.
The crank itself is bolted down with 3 torx bolts - in order to do it right do I have to remove that drive-side crank arm?
I didn't do that and I monkeyed with that chainring for probably an hour - I eventually wormed one side of the chainring bolt into place and married both rings AND the inside bolt into place and got it together but that CAN'T be right.
What am I missing? (other than experience
