anotherbrian
I don't mind cutting down the fork steer tube but why is there a friggin star nut pounded into the end I'm supposed to cut off?
Other than the minor kerfuffle with the steer tube the frame set looks pretty good but I was surprised to see the threads on the inside of the bottom bracket shell were cut before the anodizing or whatever the coating is that was applied as all of the threads are fully coated and the threads were not chased after this frame coating was applied. This is probably good in this case as the BB mounting caps or cups screw in very easily and there is a lot more play than I would have expected. I think Cruzbike needs to tighten tolerances here. In this case it is probably a good thing the threads inside the shell got anodized or it would be even looser. I'm hoping after torqueing that this isn't going to be a problem area.
Is the star nut in the fork steerer or in the chrome mast that slides (press fits for the frameset?) over the fork steerer? I would hope that the "complete" bike had the correct length steerer tube ... if the mast length needs to be adapted then that seems reasonable (knock the star nut down if you shorten it). I received two different length masts with my frameset and they both have star nuts installed (and one included a top cap with a rubber button that goes into the hex head of the top cap bolt), and neither has any chance of coming off the fork steerer if I put them on as far as they're designed.
