SlowRoll1950
Thanks.I built mine with a 1x11. Jenson had a good deal on the old style Race Face Atlas crankset. It came with an external bottom bracket and went on easily.
How do I get the images directly in the post?
Brad, which 1X11 setup did you go,with? Going that way too, I think. My wife is not real keen on shifting anyways so 11 speed would be great if I can get a heck of a range and trigger or twist.
I bet that is fun in the winter. Where in Michigan? I'm in Brighton.get up my 20% grade driveway ( short, but steep for Michigan)
Northville. All my motor vehicles are 4 wheel drive. Luckily it faces south and the sun helps clear it when there is sun.I bet that is fun in the winter. Where in Michigan? I'm in Brighton.
From Robert:
The grommets are for the holes where the seat base and the seat top attach.
The clear washers are for between the set base and top (there are two extras)
So rubber grommets between the two seat parts (base and back?),
but where are the clear washers? "set base and top"? If only two are required, is that the seat back and the seat stay?
Shimano XT M8000: 11-46 cassette, 11 speed rear derailleur, and 11 speed trigger shifter.
I changed the spacers on my bottom bracket to reduce the chainline at front sprocket to about 45mm. That puts less bend in the chain for the lower gears.
I am getting some difficulty holding 3rd and 4th gear. So I wouldn't say that I am 100% satisfied with the shifting yet.
I have a 36 tooth chain ring for now. Will probably go with a 40 or 44 once I can handle the speed and know what low end I need to get up my 20% grade driveway ( short, but steep for Michigan).
You can buy some cheap crankset and shorten it. I.E. Prowheel brand (http://pro-wheel.com/main/) or probably cheap SRAM crankset may be shortened.Brad,
Only problem I have with this configuration is I need 140mm crank as the wifey is only 5' 4". All these start at 165.
Anybody know of a similar way to go with a 1x11 with a shorty crank? I really like the 11x46 for her and maybe a 34-36 elliptical is my thinking!
Edit: Already have a brand new Dura-Ace SM-BB7900 still in then box that I hope I can use...
I'm sourcing an Origin8 crankset that is 155mm...but they offer 140mm. I'll be using an IGH (Shimano Alfine 8) but I think the Origin8 crankset should work fine as 1x11.Brad,
OK...sourcing a bottom bracket. Standard 68mm square taper cartridge type...but what width? 109? 113? I'm going to be running an Origin8 crank with a single 110BCD chainring...
