Brilliant!
But I wonder about the angle of the shock. Isn't a shock supposed to be as perpendicular as possible to the force exerted on the pedals? That minimizes pogoing, which occurs when the rider is pumping the shock with each pedal stroke. The original Qs had such a shock orientation, but from the photo, it looks like the new one could cause bad pogoing when pumping hard. Opinions?
Shock installation angle has absolutely nothing to do with 'pogoing'.
This is a bit of a complex topic, but if you are really interested in knowing how it really works google 'anti-squat suspension geometry'. In short, you need axle path as perpendicular as possible to squat vector, which depends on center of rotation:
https://www.quora.com/What-is-anti-dive-and-anti-squat
Linkage forks where axle path actually moves forward and up don't squat under braking, for instance. (But bump compliance suffers, I suspect) - because their axle path is nearly perpendicular to squat vector, while conventional forks are nearly parallel to it, plus there is forces at the tire and calliper to think about. Due to a combination of this factors some linkage forks (on motorcycles) actually RISE under braking.
Since we don't deal with chain forces and brake forces on FWD bent's rear suspension when simply pedalling along, 'suspension bob' is, in fact, due to 'sine wave' of acceleration and deceleration due pedal strokes and air/gravity/rolling resistance and resulting weight transfer.
Having a rearward axle path will help here, and due to high pivot it WILL be a bit rearward. Plus, due to longer wheelbase and relatively low CG of bents suspension bob should be much less even with 100% pro-squat geometry - due to much less resulting weight transfer.
TL;DR:
No, it is not a problem at all.
