DuncanWatson
Thanks for the link to the deal. You just saved me a bundle. I won't get to use it until Christmas though
Perfecto .... just ordered. (the girlfriend caught me buying it "but you already have a helmet, why do you need another?")Just found a Great price on the Giro Air Attack helmet if you're in the market for one. https://www.westernbikeworks.com/product/giro-2015-air-attack-shield-helmet
Price usually only good for a day or two with limited size and color.
Oh and as much as everyone on here claims this bike climbs better then other recumbents, it still feels very slow and heavy compared to my 16lb DF road bike when climbing 15% sustained grades.
RojoRacing, thanks for your comments and observations...interesting and a good read.
I am also finding with my "new" Vendetta and have found with my long-owned Sofrider that climbing hills isn't as easy or as fast for me as I remember such when I rode DF bikes.
I never really payed much attention but when descending on a DF bike you alway weight you feet and lighten the contact point of your ass so it gives you a touch of suspension. On a recumbent you can't do that so a dip causes your body to load the frame with energy and it's then released on the upswing and you end up airborne. This is probably not a problem for most riders since they wouldn't be going that fast in the first place but like I said, it was a very surprising experience.
I noticed the same "heavy" feel when climbing as a new Vendetta rider this spring. This is because my bike weighs 28 pounds, which is 11 pounds more than my carbon DF weight. What happened over the summer was that I was forced to carry that extra 11 pounds up every hill when following the DFs. That extra work made my legs stronger at climbing. Now I can use that strength on the flats and downhills. But the amazing thing is that I can effectively climb against the DFs now. Often, I can out-climb them. Now, the strong DF riders who are also good climbers can sometimes out-climb me, which is to be expected - but I can usually climb pretty well. For instance, I was on a 66-mile ride with two DF riders (one a strong climber) and I left them both way behind on a long, difficult climb with no preceding downhill - I made it over half way up at over 20 mph. On the same climb previously with a large group of DF riders, I came up from behind, passed most of them on the hill, caught some that were ahead of me, crested, and blew past the one rider that had beaten me to the top of the hill (because of a head start). So I think I'm in a good position on the bike for climbing (due to the MBB), but the difference now is that I've adapted to climbing on a V, both with "bent" legs and more power output. Also, this extra 11 pounds makes it harder to sprint, since more weight has to be accelerated. The only solution for sprinting and climbing, other than becoming stronger, is to drop as much weight as possible (from both body and bike) to compensate for the heavier bike.Oh and as much as everyone on here claims this bike climbs better then other recumbents, it still feels very slow and heavy compared to my 16lb DF road bike when climbing 15% sustained grades.
You really can't escape the, if you want to climb hills better, then go climb hills. I suspect that when Jason get's his bent legs he'll find the same. Just gonna hurt more than normal due to the timelines. My solution to the problem was to loose 25 lbs, but that only worked because I had 25 to loose.That extra work made my legs stronger at climbing.
Your racing experience showed right there.I called it a day.
shove the pump under the seat
That is the common consensus; had a couple or use had a couple bag makers lined up but this little community project keeps stalling; it going to get another go this winter hopefullySomeone needs to make a triangle shaped bag that takes up that whole area between the frame tubes and in front of the wheel so it's out of the wind.
