A4X speculation
Which features will be available on the A4X
  • Adjustable seat angle
    Votes: 10 90.9%
  • 650b Wheels
    Votes: 5 45.5%
  • > 50mm clearance
    Votes: 8 72.7%
  • Front suspension
    Votes: 1 9.1%
  • Rear suspension
    Votes: 11 100.0%
  • Carbon Fork
    Votes: 1 9.1%
  • Electric Assist Optional
    Votes: 8 72.7%
  • Electric Assist Standard
    Votes: 2 18.2%
  • More Mount Points than you would want
    Votes: 4 36.4%
  • Long Wheel Base
    Votes: 2 18.2%
  • Total voters
    11
Couple of questions :
  • What's the BB spec needed ? BSA Threaded but what's the width? 68 or 73? (or more?).
  • What kind of mounts for the brake calipers? Flat or post mounts?
  • Wheels : what is the stock rim width? Model of the Chosen hubs? (if buying the full bike).
  • Also related to wheels. Without going the custom built route, I can't seem to find a good source for a set of 650b wheels with 12x100 and 12x142 thru-axles. Gravel have the right hubs but almost always 700c. MTB is mostly 29in now (and usually boost). Getting 27.5 wheelset with a rear 12x142 non boost is easy but they usually come with 15x100 front hub. I know it's just a matter of putting an adapter to fit a smaller axle but I'm wonder if the frame has a notch or anything that would prevent the larger endcaps to fit? Can anyone at Cruzbike share a picture of the INSIDE of the rear "fork" ?
BB - 68MM English Thread
Brakes - calipers are DOA - there are "mounts" but the lust for wide/larger tires moves them too far away for calipers to be used (on ANY bikes) - the disc mounts are flat mount style.
Wheels - 142x12mm drive and 100x12mm rear. There is a notch there but I would have to check if it can accommodate 15mm caps for an adapter - give me a day to get a few pics of this Ill post one here.
llavalle
The order page goes live on the 17th. If you are on the email list you can get in on a few bonus "coupons" (not sure for the frame set though) so it is worth to sign up for that email ASAP.
I got the email with the sneak peek "Last chance to join A4x insiders" but the "click to join the insider" list never worked here for some reason. Where can we sign up?
I meant disk brake caliper. Not "caliper brakes" :D . My question is the mount on the frame. Flat mounts (like gravel or road bike) or Post mount (like mtb).
For example, the TRP Spyke are Post Mount only. Caliper has "ears" where you put the screw and it's threaded in the frame.
The TRP Spyre (not Spyke!) are available in both Post and Flat mount.
Flat mount are bolted in differently - you put the screw in to the frame (or small adapter plate) and it threads into the caliper. No visible "ears".
Checking the pictures is hard to see. The caliper looks super close to the frame but pics are from the right side so hard to say.
Thanks for checking the notch. I've seen some that are only there to help you a bit when putting the wheel in but the notch isn't actually touching when the axle goes in. 12mm thru-axle hubs are usually have a 19mm OD on the end caps. 15mm usually have 21mm OD.
My question about the wheels you sell with the complete bike : what is the width of the RIM itself. Giving me an idea of which tire size I can put on there.
llavalle
Humm...
Just found this https://forum.cruzbike.com/threads/q45-700x32c.14546/
2 things in that thread :
-The rear of the Q45 fits the wider outer diameter of the 15x100 hub he used.
-700x32 left 12mm (1/2in) clearance between the tire and the fork / shock mount
This is VERY interesting :D
This means that if the rear of the frame on the A4X is the same (for the axle), it would also fit. This also means I could maybe pickup a set of 700C wheels with the actual 12x100 (if the clearance on the back of the A4X is the same)
I also found this :
(which was updated for the A4x!)
It states this :
  • Cruzbike Q45 Adventure Bike - 650b stock wheels and can go to 40c
  • Cruzbike A4x Adventure Bike - Stock 650b wheels accommodate tires up to 57mm (2.25") wide; swap to 24" wheels and clearance opens up to 68mm (2.6") for even more capable rubber on demanding terrain. Note: fender installation is not compatible at maximum tire width
Assuming tire width = tire height, from a pure math perspective, 650b with 57mm is exactly the same as 700c with 38mm tires.
The math :
Bead seat diameter of a 650b is 584mm. Add 2x 57 and you get a total wheel diameter of 698mm
Bead seat diameter of a 700c is 622mm. Add 2x 38 and you get the same wheel diameter of 698mm
Did the same math with the 24in wheels but I assume the limitation in that case is the width, not the diameter.
I know this isn't exact at all but I have 700c wheelset I could test :D
And lastly - Modifying the end caps of a 15x100 hub seems pretty easy. Chuck it in a late and reduce the OD from 21 to 19mm. Then install a 12mm to 15mm adapter shaft in there for the proper axle diameter.
Alright, when can I order this frameset and get started on my build? (I know, I know, March 17th!)
llavalle
Alright, we had enough rain to melt the snow. First ride on my Optima Cougar - after less than 3min I was able to do this! I'm sold.
So we're talking tonight at 11:59PM or like 9AM tomorrow ? :D
NVM, the email says "The all-new adventure bike opens for orders 3/17 at 10 a.m. EDT"
Bronze or Blue? :D
Damien
"I really love the design – you definitely won't mistake this bike for any other. Great job! Hope it sells well. I’m personally a bit skeptical about FWD (front-wheel drive) off-road, though.
Boreen bimbler
I've ridden my S40 off road. It certainly had it's limits (as you can't stand up obviously) but it was suprisingly capable. A bit of suspension would have made a great difference in comfort and wider tyres than my 38mm would help too. So I think the A4x should be pretty good on tracks and paths. Maybe don't take the black routes though. :p
llavalle
Bronze or Blue? :D
Ordered! (Bronze frameset + a few accessories like a spare droupout, the A4X frame bag and the ventisit seat)
Can't wait to build it and ride it!
It does not appear to me that there is room in the dropout notch for a 15mm hub cap. Also pics of the brake mounts - flat mount with both front and rear using the same adapter (this is the same as on the Q and the S.
Robert
llavalle
Robert
Thanks for following up.
Indeed - that looks tight. Just ordered the frameset, I'll take full detailed measurements when it gets here.
Perfect for the brakes!
Elisa
I am wondering where do you place the water bottle for access while riding? This is an issue with the Q45. On my Q I have placed it on the boom with velcro attachment.
Mounting to the back of the seat with the spacer works great. Personally I drill lower holes for an easier reach.
It is a difficult/awkward reach when riding
I'll admit, I agree this is one of the few things I find less optimal about my Cruzbike. I am grabbing my bottle from my race cage behind my neck, and I can competently reach my bottle and return it again, but I find it irritating, especially since now the bottle is upside down. I did try to teach myself to drink that way, but generally I just ended up with water all over myself. These days, I retrieve the bottle, rest it against my chest to turn it the other way, take a drink, rest it again to turn it over, and then put it back. That's not great. Maybe I will try hard to practice drinking with the bottle upside down. I don't see a better solution though. I'm not a fan of bladders, and I don't have the mobility needed to grab it from the cage along the seat back.
Other than the long wheelbase days of old - ideal bottle positioning has always been something of a trade off with recumbent bikes. Nearly all recumbents go for a behind the seat solution. Another possibility you CAN do is on the top of the boom as you mentioned, and also the Q has enough room for my fave - a handlebar cupholder. Here is a pic of my cupholder that I used on RAGBRAI last year. Another option I am also currently working on is a side rack attachment that would put a bottle under the seat.
You can drill two holes in the seat base and do an underseat mount, but I find that less ideal for road debris/dust getting up onto the bottle.
I like the back of the seat idea. I use that on my S40. Especially if they are low. Practice it. It shall soon become second nature.
I don't like adding weight to the boom or the handlebars (especially a water bottle). It affects the handling of the bike.
Henri
scatter brain
Behind the seat might be a good place for Fidlock? You don't have to slide them in from the top, you just kinda "smack 'em on".
The custom frame bag has a bottle pouch on the side. (Store two behind the bag and have one accessible down there.)
The pack mounts on the rear swing arm should also work as bottle holders? No Idea, how well you'd reach them. Might want mudguards.
Bo6
I just realized something.
Complete bikes have 13% tariffs applied to them when getting into Canada.
Bike parts? 5%.
Just tested that with your website and it matches with a T50 for example.
That's 8% difference that is just "burned" for no reasons. I don't mind letting Cruzbike take a cut on components but paying extra duties "just because" feels such a waste. I was a bike tech in college and still have all my tools. The only thing I wouldn't take now is building a wheel from scratch (just don't have the patience :D). I could also pick a another 1x12 drivetrain
So looking at a frameset. Looks like to complete I'll need :
-Set of wheels (24in, 26in or 650b)
-Tires
-Disk brakes with rotor and levers
-Grips
-Drivetrain : rear derailer, chain, crank and chainring + shifter
Reason I ask about the 15x100 is that I can get a pretty nice set of Ztto DR390 wheels with 27.5in rims and a microspline freehub for less than $300 CAD, shipped but they don't seem to offer them with a 12x100 TA, just 15x100.
Alternatively, I know that shipping a frameset + wheels means shipping a bike (so 13% duties). Could you ship the factory wheels separately? I'm guessing Chosen makes micro spline free hubs that I could swap. Might not be possible put thinking out loud right now
That's really cool to hear!
I am in Canada and got a V20 frame set. Do not remember all the details but ended up getting the bike set and I paid the duty at my end. Customs still charged the higher rate initially and I set them the required form and details to request a review base on the fact it was a set of parts without wheels etc and pointed out the appropriate customs regulations. They eventually refunded the difference.
I used Hunt 650b wheels on My Q45 I am sure with a bit of searching you can find others.
