If you’re doing it right it should be very hard the last 1/3, that’s the point.
Yes it is hard at the end, but is that the best way to ride it? We know it is ineffective to go out too hard and die off early and it is equally ineffective to go out too easy and try to make it up at the end. So I am thinking that on the next ride I will ride the first six miles at my last PR average speed which should leave gas in the tank to ride last six miles at a moving average PR+0.2mph (by the end of the TT) pace. If you are riding consistently hard each week and getting sufficient rest, then you should have extra capacity in the following week. I will try to only use my weekly increased power output on the last part of the ride when HR is typically rising too high. It is a way of spreading out the pain. Maybe, maybe not.If you’re doing it right it should be very hard the last 1/3, that’s the point.
Thanks Maria and Bill - it is amazing how much time this takes each week - but since I am a "numbers" junky I guess it works out! hahaDitto on thank you for the hard work Larry. I have a general forum question. Until about a few weeks ago I have been pacing myself with my heart rate to max it out without going redline and so get a good time and perhaps a PR. I changed my tactic to choosing an average PR speed plus .2 to .4 mph as a goal to finish under. As I approach the start at speed, then I start my ride GPS and monitor average speed first, and heart rate second throughout the TT. This seems to be working but can be a killer in the last three or so miles. Does anyone have a better method that they would be willing to offer?
Thanks for all the advice. I looked at the Power Curve from Strava analysis plot and pulled out essentially 200 watts at 1 hour on a smooth curve. Your calculation of 1.1 times FTP for 30 minutes was spot on for last TT for which my average (~30 minute) power was 219 watts. I will switch metric for next TT from average Speed to average Power. I will still try to finesse it by maintaining average Power from last PR in first six miles and then try to ramp up to an average PR Power + 5 watts by the end of the TT. That should help accommodate elevation and wind influences as you stated but also help reduce the power "fade" toward the end of the TT. Fun stuff to try out.Still best advice it to pic an average power you want to maintain (which might be a little higher than you have done previously) and work on that aspect.
I see you switched from your yellow Vendetta to a Volokraft Nocom. Are you happy with the change?It finally uploaded. took 24 hours for it to show up on my YouTube page but it finally did so I can finally share it. Unfortunately the software I use to edit wont allow metrics to be added from my Garmin computer and i was not able to add commentary to the video without changing the format to panoramic which i think defeats the purpose of a 360 video. The time trial starts at about 45 seconds in just after i pass the white house on the right. The camera is mounted vertically to the tiller of my Nocom about half way between the pivot and the gunners. The view is a bit wobbly because of this but then again I do wobble side to side on this bike a bit. if viewing on a phone you should be able to pan around with your finger or just move your phone left, right, and up, and down (I know you looked down) 360 in all directions. if you are on a computer you can use the mouse to click and drag the view. I was racing against more than just my self last week as the dark blue sky area is rain that was moving towards me in central Indiana Sunday. Also if you know of a better software to use to edit 360 video from a Samsung gear 360 I would like to try it out.
Very cool Lief - Yes, this is how it is done in real life (and how I will do it at this year's retreat TT) - Everyone leaves in reverse order of their PB, with "secs" in between the deltas from their PB. If everyone rides their PB, then you all reach the finish line at the same time! It is pretty cool. This is what Alvin Maxwell does every Thur in Wash, NC. He has anywhere from 10 t0 20 people turn out each week. A lot of funThis Friday he only gets a 4m 15s head start.
If we can synch up with Robert some day it would be fun to have a three-way handicapped race to see if we can get all of us finishing together!
I ride both the vendetta and nocom interchangeably. I intended to ride the Vendetta in this challenge all the way through but week two I had to switch. Since that switch I had not ridden the Vendetta until last night when I went riding with my teammates and the route is hilly so the vendetta does better on that route. I tried to ride that route last week with them on the nocom because I had forgotten to switch out which bike was in the car that morning. That ride ended abruptly when I hit a crater (pothole) that made the front wheel look like a heart and cracked my rear zipp disc. I was able to switch the wheels out for my open wheels for last weeks TT and still got a pb. Only 2 seconds off my best for last year with the covered front and zipp rear. Went off topic there i guess. In the end I love riding each of these bikes. The nocom is faster over a longer solo race for me but the vendetta is better at hills and I can sprint faster and draft better on it so each one has its place under me. The ct700 dosent see much action.I see you switched from your yellow Vendetta to a Volokraft Nocom. Are you happy with the change?
I've been mostly ignoring my heart rate except as a guide to whether I am really working hard or just feeling a bit off.Ditto on thank you for the hard work Larry. I have a general forum question. Until about a few weeks ago I have been pacing myself with my heart rate to max it out without going redline and so get a good time and perhaps a PR. I changed my tactic to choosing an average PR speed plus .2 to .4 mph as a goal to finish under. As I approach the start at speed, then I start my ride GPS and monitor average speed first, and heart rate second throughout the TT. This seems to be working but can be a killer in the last three or so miles. Does anyone have a better method that they would be willing to offer?
Speaking of abrupt endings to rides but without expensive broken hardware, tonight I had my first TT fail. I was paying too much attention to my power levels and not enough to the road when I got too far to the side and into some fresh mud deposited by dump trucks entering the road earlier in the day. My choice was to lose steering and crash on the road or continue in a straight line off the road. I chose to continue off the road and went into a huge deep mud puddle. It was like a NASA deceleration sled with mud flying everywhere. Only thing I broke was a rear light bracket. It was a good way to crash from 27 mph. I was glad to have a visor on my helmet covering my glasses. I had to remove the mud covered visor to see my way home. I will try again maybe late Friday night.That ride ended abruptly when I hit a crater (pothole) that made the front wheel look like a heart and cracked my rear zipp disc. I was able to switch the wheels out for my open wheels for last weeks TT and still got a pb.
I don’t know how you stay awake. No potholes, cars or even other cyclists to dodge.
They pave the farm roads down there in Indiana? Wow, you guys got money or something.
I sometimes feel like I practically live in a 3rd world country here in Michigan.
Wow - is all I can say - If I had to think about all those things while I am pedaling and breathing as hard as I can - either my brain would explode, or I would just stop pedaling to think about the other things!With no power meter, I have to use HR and previous performance as proxies. I've been working on the turbo over the winter with some progressive power workouts so I have a reasonable idea of where the HR is vs power in those controlled circumstances, and how much pain I'm willing to put up with. My TT course this year is not suited to managing it as a steady HR with lots of turns and short, sharp changes in elevation. My mindset has become one of splitting the course into sections and replaying in my mind the characteristics of each part that I need to achieve. I'm thinking at various points of HR, cadence, current speed, average speed by a certain turn etc and then the details of at this turn, I take this line and don't need to change gear, move to the right here to avoid a patch of rough tarmac, hit this hill hard as it has a false flat descent afterwards, but this hill is double crested so I need to have something for the second bite, max the HR here as you've got a downhill coming...
After that it's just 30+ minutes of grinding agony, just for the hell of it.
Wow - is all I can say - If I had to think about all those things while I am pedaling and breathing as hard as I can - either my brain would explode, or I would just stop pedaling to think about the other things!![]()
