Mathew Fy
GRU
Here's one leg of my revised TT course. I'm getting better with the U-turns. There's some sound issue due to copyright demands.
https://youtu.be/5OwspNWPzu4
Wow Larry - I don’t know how you can ride with that sun glare. I’d crash for sure.Here is my video from today's ride on my TT course includes description of my V20 and equipment
Sometimes it is pretty bad - just like when I was learning to drive a car: my dad told me:Wow Larry - I don’t know how you can ride with that sun glare. I’d crash for sure.
I think an equipment change is fair game.Dumb question time:
Would it be considered cheating to change configuration? The swelling in my foot has gone down enough that I can squeeze into real cycling shoes. So would it be considered fair if I ditched the block pedals with toe clips, heal straps and high topped trail running shoes for light weight cycling shoes and Look pedals? How about wheel covers? Since I have three, all with round spokes, that could make a noticeable difference.
Yup - this is fair (a total bike change from upright to bent would not be - and would require a similar process to when someone changes a course) - but - yeah - put some wheel covers on, change shoes, put a skin suit on - at this point some of us are looking for minute changes to help us out.Dumb question time:
How about a change between similar bents?Yup - this is fair (a total bike change from upright to bent would not be - and would require a similar process to when someone changes a course)
This morning I went out hoping to test my potential for improved times. In the past, I’ve raced in snow, where handling makes the biggest difference in finishing results. Or orienteering, where map reading and route planning are a huge deciding factor. I’m new to TT and the whole power is king thing.
This morning I went out and did the first half of my TT hard and made a good gain on my previous pace. I then looped around at an easier pace - my TT pace from week 9 - for 45 minutes or so. Then I did the second half of my TT hard, making another decent gain.
How do you experienced TT folks think that will translate to doing the full TT? Should I be able to retain most of the gains on the split run?
I did ride a lighter, more aero bike than I have being using to date.
I'll settle for a nice cool night with low humidity, my models say I could put out some real power and speed. The strange thing about my course is that stronger winds make the bike speeds faster because the prevailing winds are blocked where it hurts speed and I get some tailwind on other legs. Also it is clear that a cool night does not always offset high humidity. I will have high predicted power but low predicted speed in those cases and you can feel it. Though the night is cool, if the humidity is high it is like riding through pea soup.Would it be considered cheating to change configuration?
The rules say as long as you stay in the same class you can change. i.e - If you ride an upright stay on an upright, etc. If you are on an upright you cannot change to a bent, or a velomobile, etc.How about a change between similar bents?
In particular, a stick with 20/26 to 26/26. Both steel frames. My 26/26 has faster rubber, loses the fenders, lighter toolbag, tighter top end gearing. I could swap parts, but I have two bikes so I don’t have to.
I'm pretty sure I've gained a minute just by better corner lines. Much of my route has pretty rough asphalt and the shortest line isn't always the fastest. Smaller gains by learning where the wind channels, so I can take a little boost. My ace in the hole might be finishing with an early Saturday ride because traffic has proven to be super light. So far I've been going early in the week, just in case I need a redo.I haven't done anything to my bike (other than clean the chain, once). All of my gains are on me. On the other hand, my gains are racecraft as much as they are fitness. It really helps to find the places in your course that slow you down, and improve those spots. Which you can do without any change in your overall fitness.
I think that's one area where the IRL riders do have an advantage over Zwift. There's no picking the line in Zwift, or finding the right time of day when traffic is low so you can get a good run in.
