Danieleg
Hi,Does the bag get squeezed when the bike is tilted?
Since the wheels are moving top-down and not right-left, the distance between them remains constant while Tilting.
So the bag, properly fixed, doesn't get squeezed.
I prefer rocker boogie.Balor said:rocker bogie
Is the Cruztrike idea still alive within Cruzbike?
I am guessing that it is keeping the piece that is bolted into the stay from ever rotating.This may be a daft question, but what is the point of the crosspiece in front of the axle, under the frame?
Dave - having worked with PVC a lot - and knowing how brittle it is -aren't you worried about it cracking due to stress - especially when hitting a bump.
Can't wait to see how you solve the "lock-out" issue when stopped.![]()
In the case of my design, you get balance assist near vertical, which means you can putter away uphill slowly without falling over at far lower speeds than normal. You can stop at a light without unclipping. Etc yadda yadda.
I took a non-tilt-lock approach (balance assist != tilt-lock) so I couldn't forget to disengage the tilt lock and then roll during cornering.
I wanted to make something that could get me to a steep, slick-with-rain, smooth asphalt hill.
