Has anyone tried this pedaling technique to increase average speed? Let me explain...
One way of increasing speed is by increasing power. So, instead of pedaling at a constant 200W for four hours, we can get stronger so we can pedal at 210W for four hours. However, it's hard to build up that level of endurance. And it takes more time to recover from an effort like that.
Instead of trying to ride at the same power for hours, pick a more doable "cruising pace," say... ~20% below the maximum sustainable power you can maintain for 3-4 hours. For me, this is about 170-180W (when I'm in shape anyway). This would be whatever pace you can comfortably maintain, say, a 20+ mph average speed over flat terrain.
As you're riding at that "cruising pace," ramp up the effort slightly for 10-15 seconds to increase the speed to 22-23 mph. Back off the effort to the "cruising pace." Then, whenever you see that you're starting to slow down (maybe in 45-60 seconds), do another 10-15 sec effort to bring the speed back up. In terms of power, cruise at ~180W, the 10-15 sec ramps would be 230-250W.
Compared to a DF bike, the V20 keeps its speed so much longer. This pedaling technique might prove to be faster overall, but without as much load on the legs over time. Thoughts?
(I wish my hub-based power meter was working so I could have some more accurate numbers. But it hit a rock last fall, bent the rim, and I haven't taken the time to build it around a new rim. Soon.... Hopefully the above power numbers are close enough--I'm going from memory of last year when I started to experiment with this.)
