My home rail-trail is muddy in spots, so one of the first things I'm going to want to do is add fenders to my new Q45. In the youtube video about fender installation, Robert recommends Planet X ALX fenders. Two questions: (1) is that recommendation still good, and (2) the 27.5 version of the fender set comes in 2 widths: 50mm and 60mm. Which one do I want?
Thanks.
1. I woułd second that recommendation or better yet Axiom similar or sks similar if they still make them. (In one video Robert suggested raceblades or similar but I don’t have experience with them and would guess that there are concessions to frequent removal. )
2. That depends on how wide your tire is which is also affected by rim width. Basically you need something thar can fit over your tire so that nothing on the tire and being flung off gets past the fender. Factors: wider gives more room for error, wider could be harder to fit within the fork, wider creates more drag.
I always go a little big with more clearance because that leaves space for snow, that leaves more room for keeping on going rather than having to stop and adjust, I am not super at fitting them. The polycarbonate plastic ones are nearly indestructible except for the built in mounting hole for the chainstay bridge attachment. Make sure that is not stressed when mounted ( bolt goes through at an angle instead of perpendicular to the fender). I imagine the Aluminum version is the same and possibly even tougher.
Best practice is to use two rear fenders or one rear and two front fenders so that you get coverage for your whole drivetrain including the bottom bracket.
