We all know that DF bikes are uncomfortable, but bending over backwards sounds even worse. Balor's designs are getting really weird now.
Technically, bending over backwards is getting recumbent .
What you are both doing instead is engaging in rhetorical hand waving, and making comparisons to road bikes and rowing machines, the mechanics of which are completely different than what we're discussing.
Why exactly rocking a road bike is different from boom swinging? In both cases your handlebars are NOT connected to your cranks and you only manipulate your distance to pedals via them.
Yet DF races do it. *I* do it on DF, and I think it gives me more power. I do it *instinctively*, too. Have you ever done it yourself?
Basically, let's restate the question: since mechanism of boom swinging and DF bike rocking are obviously similar (I'm not talking about handbikes), are there any REAL studies that show effect of bike rocking as compared to, say, sitting sprints?
Bar pulling (BOTH handlebars) is simply an alternative method to brace for power delivery instead of pushing against the seat.
You might have a good point - pushing into the seat with related muscle contraction might well limit your lung capacity and perfusion... at least, ehehe, for YOU. Like I said, I never even breathed hard when I switched to bents at first - I simply felt like I contracted some wasting sickness and my legs simply refused to pedal as they should! Only much later I became more taxed when it comes to breathing.
If 'bent lungs' was the only theory to explain bent adaptation, it would be the other way around - I'd be constantly gasping for breath like someone breathing into a plastic bag at first and only later it would get easier. It totally might be true for some positions, but my brief tests suggest that this is just not so for me.
Plus, it does not explain why power is so much more limited in anaerobic, not aerobic spectrum or the mystifying 'cannot into high cadence' issue. Or why "scraping" seems to work much better on a bent - even for an initial sceptic like Osiris.
Work is force times displacement.
When you simply pull on the bars, or swing them on RWD, you are not displacing your pedals relative to your pedal stroke.
When you swing the boom, you DO. If you fix your leg (say, right leg) and swing the bars to the LEFT (so boom swings to the right as well), the pedal will rotate slightly *against* your leg, try it. (Having wide Q-factor helps as well)
Voila, you did some work with your upper body that goes into propulsion without producing any WORK with your legs.
How much does it contribute to your total power is a question that I am not equipped to answer, except 'likely not much'.
I think rocking a DF from side to side during hard efforts allows one to enlist different muscle groups while, in alternating manner, resting others. It also allows the rider to brace themselves against the handlebars and pull while pushing the pedals, especially when off the saddle.
In essence, the swinging boom on an MBB recumbent allows a similar action but on a more horizontal plane. The swinging of the boom may be less extreme and less obvious ( than on a DF ) but it's definitely there. (If you place a camera on the handlebars and record your shoulder motion when climbing you will see it.) One needs to brace against the handlebars when generating high torque on the pedals on an MBB bicycle.
Looks like the proposed fixed vs freely moving boom test has already been conducted
https://cruzbike.com/forum/threads/...oom-recumbent-bicycle-power-production.11644/
Balor, I don't believe 90% or more of what I read WRT bent forums simply because the posters do not use power meters and if they do, they almost never employ a control let alone correct or even appreciate differences in environmental conditions and their impact. It is often said power decreases with a lower angle on the seat. 100% not true in my case and I have the power data to prove it. Most poster just say stuff like....I breath harder with the lower seat and I was huffing and puffing up the road to my house or my average speed on my 20 mile loop was 1 minute less. Useless.
Check out this blog post, I wholeheartedly agree with what the author wrote. I think there was a 50 page mess over there on this topic and the only two riders who knew half a damn no longer post there. I gave a link to Steve Hogg who in my opinion is one of the top fitters worldwide. I spent my first 9 months of benthood focused on the damned legs with very little effect. 3-4 months on breathing has been an absolute eye opener. There is research out there on lung function by different body positions. I have a couple secrets that got me massive aerobic power improvements jsut from how I breath but since it is N = 1, I don't want to ridiculed.
http://www.fietsersafstappen.nl/english/focus-breathe-how-to-climb-fast-with-a-recumbent/
I could not make more than 525 watts Peak Power for a long time on my bent and even with a lot of power work on hills and 10x1 intervals, I can't come close to your peak power numbers.
You make a lot more power across the board. Or your power meter needs calibrated. Is there another possibility?
I know for sure his numbers reported are about right based upon racing with him and his reaction to some tests.
I've read this article long ago in beginning of my 'adaptation' period and it, frankly, it made zero sense to me for reasons I've described above.
Again, let me show:
DF, a Chinese niner with 2.35" tires, 600mm bars and stubby aerobars I use mostly for downhills and headwinds because long-term use of those make my back hurt a lot:
My weight - about 90 kg, 12 kg bike + stuff
https://www.strava.com/activities/147943553
My weight is up to 100 kg, 20 kg RWD cromoly steel bent (plenty stiff, built like a tank, Marathon supreme 2.0 tires - should roll similarly if not better) + stuff:
https://www.strava.com/activities/275932010
I've spend winter on a trainer plus already completed one 200 km brevet before with rather pathetic results as well:
https://www.strava.com/activities/264455640
And let me restate - lack of breath was certainly NOT a problem! Yea, that's a lot of extra weight, but even given relatively hilly (by our standards) track it simply cannot account for such massive drop in average speed and I certainly tried as hard as I could.
I eventually got faster and faster, but it took a move to MBB bent to get anywhere near my MTB performance, and I'm still a bit short of my road bike performance on short distances (didn't do long distance on road bike, back problems).
Still, I'd be very interested if you share what you've found about breathing on a bent in particular, cause I, indeed, very limited by my breath on my current bent *now*. But it took nearly 4 years!
I guess attacking the 'why bents don't climb' problem from different angles is nessesary.
I'm most concerned about bracing and need for *rigid* bracing that my body does not really provide unless you go out of your way with greatly changed pedalling style, and impared blood flow to the legs with high BB. (Plus 'controability' issue and I think I already solved that one)
Osiris rises interesting points about cadence.
You about how bracing and body position also affect your ability to breathe effectively, that is pretty important for anything but 5-second power brackets (which actually suffer the most on a bent).
Marco Ruga has interesting study about transmission efficiency on MBB vs RWD.
ALL of those must be considered and put together to create a more or less comprehensive model of a bent that maximises aerodynamics, comfort, transmission efficiency and power delivery across all power brackets - and how they interact so one can maximise one or the other without significant impact on other parameters.
The control run should be with hands on the bars and no pulling, just resting.....assume this would work on the trainer.
You and Aerolus want proper studies. Scientific studies.
Honest question. Have either of you ever funded such studies in any field or have you reviewed and approved such protocols or results? There just is not that kind of money in this industry.
Jim's hung weight and torque measurement is sufficient for me on the other matter at hand.
Here's a video using the trainer while monitoring the cadence, heart rate, power, and incline as it happens on Zwift. As depicted in the video you can easily switch from no hands to hands, push-pull to pull-push. The Neo is suppose to be one of the most accurate smart trainers out there. This should work if you can maintain a constant rpm or wattage. Easier said than done but ball park is doable. I'll see if I can talk Connie into playing to see if the results change since the bike is fit for her.
