Osiris
Can you post a pic of the setup w your hands on the grips? For the life of me I can’t envision a comfortable hand position. Probably just my limited 3D imagination.
![DSCN0238-XL.jpg](https://photos.smugmug.com/Sports/Bicycling/i-pHCMPCx/1/625d505e/XL/DSCN0238-XL.jpg)
The setup I had envisioned for my ride has the bar end going forward and up away from the thighs with the grips placed slightly inboard on the 7/8 inch aluminum crossbar by about 1 inch to allow a small shelf for the meaty part of the hand rest on it. My thought were to get the hands forward and high enough to get the elbows out of the wind.
I am really curious if the handing is acceptable with those gunner bars on the M1
Osiris....maybe you could give me some insight into difference of racing recumbent with gunner or tiller bars versus the V20 type bars.
I had wanted to buy a V20 but my medical condition scared me off. My left arm and hand is very weak and sometimes painful to the point I ride one handed for periods of time. I came to the conclusion (no facts, just thinking about it) that pulling on MBB bars to counter the leg action would take some effort especially on very long rides like brevets of 10-50 hours riding. Do you actually have to pull the V20 bars or is it more a little wiggle? Can you ride the V20 with one arm giving the other one a rest? On the tiller type bars, my arms just rest on my belly and do nothing. (sorry for the OT post)
It has been my experience that eventually there is no real "pulling or pushing" on the handlebar to counteract what you all "the leg action". I think the legs just eventually take over entirely. Many people can ride no hands for long periods of time. I ride with the tiny little stubby handlebar and can easily ride with one hand, and can get bottles or do other things with my other hand - or even stretch it out over the top of the boom to relax it since it is always bent with my handlebar configuration. Of course when you are putting is sudden "big power" you are going to bring the whole upper body to that show.I had wanted to buy a V20 but my medical condition scared me off. My left arm and hand is very weak and sometimes painful to the point I ride one handed for periods of time. I came to the conclusion (no facts, just thinking about it) that pulling on MBB bars to counter the leg action would take some effort especially on very long rides like brevets of 10-50 hours riding. Do you actually have to pull the V20 bars or is it more a little wiggle? Can you ride the V20 with one arm giving the other one a rest?
I finally completed the new handlebar setup for my M1. The previous setup worked fine, but using a conventional V-shaped handlebar resulted in the brake levers facing the wrong direction, causing almost the entire surface area of my XL hands to be facing directly into the air stream. The picture below also shows how cluttered it looked. On a bent designed solely for speed, this was far from ideal, so some radical redesign had to be done.
This was the design I came up with to replace it:
The horizontal crossbar is just a piece of 7/8" aluminum tubing, sourced from a hardware store, while the grips on the ends are made from a set of Bontrager mountain bike grips with the curved ends cut off. The Di2 TT style shifter pod has an expander plug on the end which fit perfectly into the aluminum tube.
When I removed the existing handlebars, I noticed that the manufacturer of the tiller had done me the favor of drilling a large hole in the base of the handlebar clamp. This gave me the idea of routing the electrical wire from the shifter pod internally through the crossbar and down the length of the tiller, where it exits through a slot and plugs into the Di2 junction box. Very clean and aero. Eventually I'll want to wrap some bar tape over the grips, but I need to do a few test runs first in case any further tweaking is required.
After some experimentation, I angled the brakes outward slightly so that the levers would fit into the web of my hands for best leverage and comfort. This also made it possible for my thumb to press the shifter buttons without interference from the lever, so that I could operate the brake while shifting gears if need be. On the left side I installed a bar end mirror which had been in my parts bin for years. Positioning it as shown behind my left hand keeps it out of the airstream. As before, the width of the grips positions my hands directly behind my thighs when pedaling, thereby hiding them from the wind as much as possible. On the trainer, everything worked flawlessly. Shifting up and down through the gears is effortless, and the Cane Creek brakes seem to work quite a bit better than the ones they replaced. All that remains now is to take it for a test ride.
That bar end mirror has probably the worst cda component of anything on your bars...
I would love to see some cda numbers or comparison of skinsuit vs rumpled jerseyOh, it definitely is my size, despite it's tightness. Not a wrinkle in sight. I can't see wearing it for very long, though.
Seeing how smooth and aero my skinsuit has made me, I'm now more conscious of various parts of the M1 that could use a bit of smoothing, starting with the crankset, which I'd want to look more like this:
I saw an interesting "result" happen with "rumpled jersey". I was at the A2 WindTunnel with Cruzbike a while ago. Jim Parker put his skin suit on (no small feat by the way) - went in the wind-tunnel, came out, switched to his super loose, flapping in the wind Jersey and go a lower cda value. That is where I stopped thinking about trying to pour myself into the skin suit. Not sure everyone would have the same result, but perhaps the skin-suit helps more when you are in the up-right position.I would love to see some cda numbers or comparison of skinsuit vs rumpled jersey
I believe it is because of the lower seat angle. I have the same thing happen to me on my Raptor (which is 11-12 degrees) when compared to the V20 (at 20 degrees), and I have compared other bikes and models too. This makes a huge difference on Zwift, where we are not given any aero advantage for being flatter on the bike. Some people say you can make the same watts, you just have to do it "Long enough". Not sure how "long" I would like to try it, but I rode the Raptor for probably 6500 miles exclusively. Instantly hop on the V20 - and make at least 10% more power. Now, the Raptor can still probably go "faster" than the "v20" on 10% less power, but I would rather ride the V20 on the open road. (I really hate chain interference) If I am on a track, I would ride the Raptor, or my Arrowhead.I was amazed when picking up the speed how much more power I could make on the V20 compared to the M1
I believe it is because of the lower seat angle. I have the same thing happen to me on my Raptor (which is 11-12 degrees) when compared to the V20 (at 20 degrees), and I have compared other bikes and models too. This makes a huge difference on Zwift, where we are not given any aero advantage for being flatter on the bike. Some people say you can make the same watts, you just have to do it "Long enough". Not sure how "long" I would like to try it, but I rode the Raptor for probably 6500 miles exclusively. Instantly hop on the V20 - and make at least 10% more power. Now, the Raptor can still probably go "faster" than the "v20" on 10% less power, but I would rather ride the V20 on the open road. (I really hate chain interference) If I am on a track, I would ride the Raptor, or my Arrowhead.![]()
I don't buy the claim some people make that eventually you'll be able to make the same watts on any platform. I've got thousands of miles of experience on various bents, and I've yet to see any evidence of that.
