Should have got Wifli.
I use 11-32 and with the B stop screw pulled out, it shifts fine.....even 53x32. Of course, the specification is 28T max. The M5 hanger or at least on mine is pretty generous in terms of length, so, mine works fine.
For the Garmin mount, I epoxied one of the mounts onto the "downtube" just below where the cable holes are for the rear brake and derailleur. Out of my face and more aero.
My only "serious" problem with the e-tap was during a 600k in Fla in heavy rain. It stopped shifting in the "hilly" Orange Groves east of Avon Park. I was stuck in the 53x25. When I got to the hotel, I took the batteries off and cleaned/dried the connections. Put the batteries back on and it shifted fine since. Why? Who knows. I get more than the stated 1000 km before needing a charge. I have around 3500 miles so far on it and that reminds me, also on the GP5000 700x25 rear tires. I would normally change it out before now, but am tempting fate cuz it looks pretty good. I do intend to bring a spare e-tap button/cable and battery when doing remote rides. I probably should have get my lazy butt off the bike in the Orange Groves and tried to shift with the blip box but I just spun and rode easy.
Just out of curiosity, what made you decide to go with the e-tap system? If it were not for my weird custom handlebar configuration, I wouldn't even consider electronic shifting. Ben Tomblin had e-taps on his M5. I gather he wasn't too impressed with it because he sold the M5 not long afterward.
My left hand and arm is weak and sometimes, my hand does not work very well and I was concerned that I could not do long randonneuring events with barends or mechanical shifters. I thought the buttons at my thumb would make shifting easier and to some extent, it does....except when etap dumps my chain or when trying to shift with winter gloves on. One of the beauties of wax? No messy hands. Also on bumpy roads in the wind when I am really cranking hard at over 30 mph, moving my hands to the bar ends could be unnerving with barends. I do like the buttons in that sense (stability). It also isn't very aerodynamic to move your arms and hands to shift. I want to break 20 minutes on a 10. I know it is a silly goal but I need some kind of target....like getting into the 190's on 3P....oops, we already did that once. Oh....my SRAM red mechanical derailleur wifl spring exploded (common defect with SRAM), so, I needed a new $300 derailleur anyways.....so, I moved "up" knowing that many pro mechanics even had front derailleur problems. I have been toying with making gunnar bars and I think etap is the only way to make such bars work on the road. Right now, I am not in a position to do it......maybe someday.
Use Molten speed wax. You chain never gets dirty and lasts about 3 times longer. Love it and will never use anything different.I use spray-on chain wax, but it still gets dirty.
I've never had a SRAM rear derailleur fail, but the front ones are known to be problematic. Mine will occasionally throw a chain, even though there's nothing wrong with the unit. I've become an expert at using fallen twigs or leaves to get the chain back on without coating my hands in chain lube. I use spray-on chain wax, but it still gets dirty. I have a set of mountain bike style thumb shifters on my M5. The bar end TT shifters were just the wrong solution for all the reasons you mentioned. The thumb shifters work well and don't require re-positioning my hand when shifting gears, but there's no way to mount them on my new gunner bar design, and the existing handlebar causes too much aerodynamic drag. I just hope that the new handlebar works as well as it does on the M1, because it's the only reason I had to ditch the perfectly good mechanical switchgear for the overpriced and less reliable e-taps.
Sorry if this is stupid, but can the V20 or other Cruz bikes take tiller bars?
I really would like a second recumbent, I had one but sold it.
A more sporty one with fatter tires that I can tour with. Tiller is a must for me.
I guess I have no idea what I am talking about to be honest. I don't know the terms. I'll figure out what the heck I mean.What exactly do you mean by "tiller bars"? I thought the distinguishing feature of a tiller is the single shaft connecting the fork steerer tube to the hand grips. If that's so, then the V20 and other Cruzbikes already incorporate tiller bars.
I was going to mount it in the boom next to the motor battery but had trouble routing the cables around the fork tube (thru the no longer used shifter hole).I spoke with the owner of the bike shop that installed the e-tap system on Ben Tomblin's M5, and he confirmed that the 32T won't be a problem, despite what SRAM says.
I also found an alternative mounting point for the blip box. I'm going to place it underneath the base of the tiller and route the wiring through the tiller, just as I did with the M1. That should make for a very aero installation with no wires showing. With any luck, I should be able to do the installation and setup myself and have it ready for a test ride this coming weekend.
