Nice report Osiris. The bars look sweet. Looks fast, too.
I'm pretty happy with the results, but I would have preferred another kind of bar tape. The shop I brought it to uses something that resembles electrical tape, and it just looks ugly. Fortunately it turns out that the blip buttons need to be moved up a bit, so I have a convenient excuse for replacing all that tape.
It started storming here this afternoon so I didn't have the opportunity to test the new handlebars; that will have to wait until Sunday. I did however have time to take the M1 for a spin early in the morning, and set some blistering times. I'm bothered by the fact that sometimes there's a little bit of air space between my upper arms and torso, which I'm sure is causing more drag than if my arms were pressed firmly against my rib cage. I'm going to try moving the grips closer together to resolve the issue. Hopefully that will also place my forearms in a more aero position as well.
Interesting you can make so much more power on the V20. Who knows.
Are you using the same power meter?
Sort of. The V20 has the newest Vector 3's, whereas my other bents have the older style Vector 2's. The newest Vectors are supposed to be slightly more accurate, but field tests show virtually no difference. What I like about the Vector system is that they measure the power your legs are actually putting out, whereas a hub mounted system would be slightly off due to drive-train losses. The downside is that it can't therefore measure any benefits afforded by my V20's FWD system, which theoretically should produce less friction than my other RWD bents.
My FTP started creeping up. I was so excited until it really went up like crazy up. 365 watts average for slightly uphill 8.64 mile segment. THEN, I knew it was screwed up. I did get 6th place on the segment and was almost coasting 20 mph on the last mile because I had no idea there was a segment there. About 2600 riders have ridden that stretch. I put another PM on....bummer. What was slightly confusing? I was getting stronger as evidenced by breaking PB on hill climbs including a few set on my upright, so, I was pretty stoked.
I hate it when I'm forced to use Strava segments for my training that were created by other people. Many of them seem to start and end in totally arbitrary places, so you can never be sure where they begin and end. The mile long hill climb segment I use is one of those. Recently I made a huge improvement, moving up from 9th place to 2nd place. I attributed that to a big increase in average power, but that may simply be due to the fact that I started the climb later than I usually do, so I had more energy in reserve.
I'm going to start training with a couple of TT racers I met a couple of weeks ago on the trail. These guys are very serious and very fast, so that will force me to train in a more disciplined manner. They like to do 7 minute intervals followed by 3 minutes of rest, done over a 50 mile distance. I'm not sure what that will do for me, but I'm hoping it will improve my endurance, which is still woefully lacking. If I wasn't on a recumbent, I couldn't keep those guys in sight for more than a minute.
Today I averaged 30.9 mph on a mile long segment. Average power was 245 W, which is the best I've managed on the M1, especially since I was already tired from two previous sprints. I had the feeling that I was being helped by a slight tailwind, but when I stopped I couldn't feel anything. I'll want to do that segment several more times to see if that power level is in fact accurate for that speed. It sounds a bit too good to be true.
